pmureika
SSA Regular
    4,084
  • Days Won
    10
Everything posted by pmureika
  1. pmureika
    SA12 Setup
    Then make sure you do the big 3 and I would go with a higher output amp to give you some head room.
  2. pmureika
    SA12 Setup
    Also are you wanting sq or spl?
  3. pmureika
    SA12 Setup
    Are you set on using sa-12's ?
  4. pmureika
    need some direction
    I have used the ssd's and I would use them again if I was building a spl setup.They are great drivers for the money.
  5. pmureika
    subwoofer decisions !!!!!!
    Why do videos impress people ? They are mostly smoke and mirrors.
  6. pmureika
    Better for what? The only way to tell what sub is the best in your particular application is to test them all, too many factors to decide. But im pretty sure most will say SSA subs are better, just how it is around here. SSA Icon > American Bass XFL > Sundown SA > Skar VVX I will take American built and wait for them. Thats how much better SSA subs are!
  7. pmureika
    Looks don't always equate to loudness. Some manufacturers use big motors as marketing ploy. Looks bigger and "beefier," so it must get louder. Not SSA!
  8. pmureika
    Parallel wiring vs Series wiring
    Have you tried it ? Soon as my new re-cone arrives I will be testing the theory. Cool it will be interesting to see the difference.
  9. pmureika
    Have you tried it ?
  10. pmureika
    Thumb drives
    Why does my usb port thumb drive sound better then a cd burned off the same computer?
  11. pmureika
    So are the SSA Gcons! I did a 138db on one 12" gcon.
  12. pmureika
    Cheers from a new (old) guy.
    To the SSA forum.
  13. pmureika
    Thumb drives
    They aren't compressed.
  14. pmureika
    I have used the vvx skars and was't impressed at all!
  15. pmureika
    At least SSA subs are built in the USA.
  16. pmureika
    WTB: amp that can do 400rms at 4ohms
    Too many threads per topic.
  17. Yes do the big three for any of the amps.
  18. pmureika
    Amp
    You have a budget for the amp?
  19. pmureika
    Need Midbass
    Sounds like adjusting the amps will help some.
  20. pmureika
    sundown e 10 sealed
    Do you need to run sealed? Mike has the best suggestion go ported if you have the room.
  21. How did you determine its a ground problem. Also you can buy a test light and go from the positive of the amp to the spot you sanded and see if it lights up. A dmm would be the better choice.
  22. There is a thing called google try that.
