4,084 -
Days Won
10
Content Type
Profiles
Forums
Gallery
Everything posted by pmureika
Birch is amazing to work with! once you use it you never go back to mdf again! Half the weight and its real wood.
I peels off after one winter.
plasti-dip Fing madness!! and a little treat haha
pmureika replied to SMpaintball78's topic in Off Topic
Read first post. -
Need A new amp?
pmureika replied to CFAIST's topic in Amplifiers / Head Units / Processors / Electrical
I have a saz-2500 sundown in excellent shape. PM if interested. -
8 Should be enough unless you plan to upgrade later then I would do four. As for pricing you would have to get a qoute from them.
D C Creations can build you one.
I think they will surprise you how loud they get? Are you using a sealed or ported box?
Good so you can wire down to one ohm. Each sub will get at least 375 watts rms.
750rms@1ohm 1%thd 1000rms@1ohm 5%thd booth @ 14.4volts What sub are you using?
How do you like those IA coax's Well they do look very nice! I can add a review to my build log this weekend when I put them in of how they perform. You dont have to.
What about the ssf filter was it set properly?
Definitely be careful with the gain. What coil config do you have? How do I check exactly? Sorry, I don't know a whole lot about all this Where did you get the subs? If you got them from SSA which did you buy Single 4 ohm or dual 4 ohm? Yes, got them from ssa. Dual 4 ohm. What ohm load do you have them wired for? but how do you have them wired. Need pics.
How much wattage you giving to the dcons?
600 total. I like the aq750 amp. that gives you 375 each or less.
300rms each sub.I would not do 500 each sub for a daily driver.
You dont need 1000wrms for dcons. A aq750 would be plenty.
Soundstream rub2.450??
pmureika replied to Dangrebel's topic in Amplifiers / Head Units / Processors / Electrical
try vminovations -
I have run the 80.4 for over a year and no problems. -
Xcon with the saame power will blow the icon away.
Charging Voltage 15.5volts
pmureika replied to MikeMartel's topic in Amplifiers / Head Units / Processors / Electrical
It could be that high if the battery wasnt charged good, but if it stays that high I would double check with a calibrated dmm.
