pmureika
SSA Regular
    4,084
  • Days Won
    10
Everything posted by pmureika
  1. pmureika
    Amp wont turn on???
    Good luck!!!
  2. pmureika
    Amp wont turn on???
    Buy some new rca's if thatt dont work you have a bad hu, not likey or your settings are wrong. hope you figure it outWhat hu unit are you using?
  3. pmureika
    Amp wont turn on???
    No some head units you can turn the subs off and on separetly.For each function like ipod ,cd,usb,radio.
  4. pmureika
    Amp wont turn on???
    But are the subs turned on?
  5. Your gain is set to high.
  6. pmureika
    Amp wont turn on???
    Or wrong hu setting or a bad hu.Read your manual.
  7. Sub sonic has nothing to do with volume. the gain does that and all songs arent recorded the same. sorry for my poor english let me try and explain it in the best way i can think. i understand what a gain on a amp does and i understand what the ssf does as well. what i'm trying to explain is on some song's i listen to i have to listen to them at a low volume since they beat real hard when i say beat real hard i mean to where my subs's will move like crazy and you can start smelling the coils burn a little or you will hear the sub pop and was not sure if it might have to do with the way my ssf is set to or if this is normal. Like I said its the way the music was recorded.Turn the sub volume down on those songs.
  8. pmureika
    Amp wont turn on???
    Did it work?
  9. pmureika
    Amp wont turn on???
    Ok
  10. pmureika
    Amp wont turn on???
    Yep plug that into the amp instead of your hu rca's.
  11. pmureika
    Amp wont turn on???
    It will alow you to bypass the hu and hook direct to amp. best buy, walmart, target
  12. pmureika
    Amp wont turn on???
    As long as the amp turns on dont worry about them.
  13. pmureika
    Amp wont turn on???
    you can buy one at walmart. the plugin to 2 rca's to plug direct into the amp instead of your rca cables.
  14. pmureika
    Amp wont turn on???
    Hook a ipod direct to your amp with the proper adapter.
  15. Sub sonic has nothing to do with volume. the gain does that and all songs arent recorded the same.
  16. pmureika
    Subwoofer Question
    If you want load do it, but the subs wont last long.
  17. pmureika
    Amp wont turn on???
    Do you have a ipod?
  18. pmureika
    Amp wont turn on???
    Then the problem is between the hu and the amp.
  19. pmureika
    Amp wont turn on???
    Wire one sub parallel 2ohm turn the gain down to start and see if its louder.
  20. pmureika
    Amp wont turn on???
    Just follow that wiring diagram to the T.But you could have other wiring wrong. Try just one sub but set the gain low.
  21. pmureika
    Amp wont turn on???
    I quess without being there I cant help.
  22. pmureika
    Amp wont turn on???
    The other thing to look for is there a volume setting for the subs on the head unit.
  23. pmureika
    Amp wont turn on???
    Each sub has to be wired exactly the same way.
  24. pmureika
    Amp wont turn on???
    He has two 4ohm dvc subs.He needs a 1ohm load.for his aq750
  25. pmureika
    Amp wont turn on???
    Set your meter to ohms and read the ohms with the wires unhooked. What does it read?
