BKOLFO4
BANNED
    1,685
Everything posted by BKOLFO4
  1. BKOLFO4
    i am official now!!
    sweet!
  2. BKOLFO4
    power question
    I would get a BTL with dual 1 ohm coils. Ohm: Dual 1 P Chamfer: no Cooling: yes 3rdMagnet: yes HiXmCoil: yes Daily or SPL: Daily Universal: yes You have 2400+ watts with those two amps. I would get a BTL over a BL with that much power. Brian
  3. BKOLFO4
    same enclosure for BL and BTL?
    Is it ported? Does that include the port? what size BL is it?? For some reason I assumed a 15. . .must have caught "15" in another title before I clicked in on this thread. . . .I will assume with that box it is a 12???
  4. BKOLFO4
    Polyfill
    What volume and tuning gave 22"? Sorry, I do not understand the dimensions you posted above. . . A 4" aero is sufficient for a single 12" sub. The flare on the port will allow for less port area without port noise. Testing has been done to show port area can be cut in half with these ports. . . At 1.9 ft^3, the 4" would need to be 15" long for a 32-33 Hz Tuning. Brian
  5. BKOLFO4
    second battery question
    No, it would be better in the back near the amps. With the small alt, and only 13 ft of cable, you should be fine with 2 ga. Brian
  6. BKOLFO4
    edit. . . What are the box specs for your current box?
  7. BKOLFO4
    Is the second battery going near the amps? How far is it from the alternator to the second batttery? Is it the stock alt, or high output? 2 ga will more than likely handle the current, it is just the voltage drop you have to be concerned with. If the run is too long, you will drop voltage when there is a large demand for current from the alternator. Brian
  8. BKOLFO4
    Polyfill
    use an online calculator like this one: http://www.carstereo.com/help2/Articles.cfm?id=31 For a single 12", I woudl use (1) 4" aero port. http://www.partsexpress.com/pe/showdetl.cf...tnumber=268-352 Use the calculator, and then add 1" to the length for end correction for the flared ends.
  9. BKOLFO4
    Polyfill
    1.9 after sub and port displacement will work. What size port and tuning frequency? Can you post up dimensions of the box you have in mind???
  10. BKOLFO4
    Polyfill
    Is that before driver and port displacement, or is that net volume after driver and port diplacement? What are your dimensions?
  11. BKOLFO4
    Polyfill
    It can work for ported boxes, but it is experimental. If you are "increasing" the size of the box, that will also lower the tuning frequnecy. It is hard to predict how much "increase" in volume you will get, so you could not predict how much shorter to make the port wall to keep the same tuning. It would be build, test, modify, build, test, etc. . . I also would not recommended, since it can interfere with the airflow inside the box, which would also change the tuning frequency. worst case it could make the enclosure react like a leaky sealed box instead of a properly tuned ported box. . . Are you tight on space?
  12. BKOLFO4
    IXL-18 and a sonotube. . .
    Sub was up and running last night. Pretty incredible driver for the money. 700 watts to it was shaking the house pretty good. I should have got a picture of the finished legs. We added 2" PVC couplings to them to look like feet. Skip is going to bedliner spray the caps and legs and cover the tube in leather.
  13. BKOLFO4
    Ordered it from Lowes. think it was $125 6 years ago. I do not even know if they can order it anymore. It came in a 12 ft section. I built a sub identical to this one with a blueprint 1803 in it. Ended up with smaller subs in my new house, so I sold the 1803 and tube to a guy in Dallas. I sold the other 1803 before I built the second tube to Chad at AA (long before AA). . . Built another sub for a friend with a Stryke AV15 in it. This sub with the IXL-18 is the last of that 12 ft section. . . Brian
  14. BKOLFO4
    my plan
    If you have the tools to dado the ends of the port walls, you can use PVC to smooth them out. Works great for multiple u-turns like that. Brian
  15. BKOLFO4
    need a box design
    Are the kickers sealed?? Do you have 13 ft^3 net after driver and port displacement, or is that 13 ft^3 gross including the driver and port displacement? I run (4) 15" BTL's in 12 ft^3 after sub and port displacement. the actual box is 16.2 ft^3 gross area. It gets pretty darn loud. . .
  16. BKOLFO4
    Need a Box Design
    You are looking for sealed, so it is very simple. . . you need around 2.6 ft^3 with driver displacement. That is roughly 4500 in^3. you can make the box whatever size you want as long as the internal legth x width x height multiplied together roughly equals 4500. Example. It needs to be 15" high internally for the driver to fit. If you made it 24" wide (22.5" internal), then you could calculate the internal depth as: 4500 / (15 x 22.5) = 13.33 or 13.25 to make it easy. Your internal box would be 15 H x 22.5 W x 13.25 D = 2.59 ft^3 I would face the sub rearward and double the rear baffle that the sub mounts on. Use 3/4" wood, so the external box dimensions will be: 16.5" H x 24" W x 15.5" D That shoudl be pretty easy to follow. If you need more help, let us know. Brian
  17. BKOLFO4
    15 bl fully loaded box help
    This will work. Around 3.85 ft^3 tuned to 33 Hz. You could double the front baffle making the box 19.25" deep and get rid of the two small braces.
  18. BKOLFO4
    Looking for 3000 watt amp
    http://www.caraudio.com/forum/showthread.p...;highlight=40.1
  19. BKOLFO4
    Grab a used IA 40.1 for $700.
  20. BKOLFO4
    NEW GUY FROM TEXAS
    As a Texas A&M grad from Denton, TX, I have been through Hearne a few times. . .
  21. BKOLFO4
    NEW GUY FROM TEXAS
    Hi fellow Texan. I am in Denton, Tx!! Welcome! Brian
  22. BKOLFO4
    BL or BTL?
    Yes. . .
  23. BKOLFO4
    BL or BTL?
    The kicker 2500 and a loaded 18" BTL would make a nice setup. . .
  24. BKOLFO4
    BL or BTL?
    BTL and be done with it. 18" if you have the airspace for a correctly designed ported box. 2000 watts is plenty for a BTL. While they will handle more, they work great with around that much power (that is what they are rated). The 06 ZX2500 would work great on a BTL.
  25. BKOLFO4
    speaker wire (gauge) size??
    A true 2600 watts @ 1 ohm is over 50 amps of current. If you were going to be burping with a sine wave, 12 ga would not be the best choice. . .
