BKOLFO4
BANNED
    1,685
Everything posted by BKOLFO4
  1. BKOLFO4
    Project over the past month.
    Thanks. . . .
  2. BKOLFO4
    IA 40.1
    I think IA will say it depends on the impedance rise. . . I am not having any problems with mine. I have been having a LOT of fun with the new subs - 15-20 minutes straight with really heavy bass music and the amps never even get hot. Running 0.35 DCR per amp and I am making a really good guess just under 1 ohm after impedance rise.
  3. BKOLFO4
    I built these at just under $1000 for materials. If I was building a set, I would have to charge at least $1600.
  4. BKOLFO4
    These things were built for loud 80's, rap, and techno music. . .and man do they perform The XO's are the ART array 12 dB/oct for the woofers. The woofer section of the ART arrays is 16 ohms, so I just built two sets and ran them in parallel. The tweeter XO is a simple in line cap like the ART array, but adjusted for a pair of 4 ohm tweeters in series. I was really worried about how they would sound, but they work awesome for the type of music Skip listens to.
  5. BKOLFO4
    Box help for assassin 8"
    Which face do you want the sub and port on???
  6. BKOLFO4
    Bl 15
    I come up with the port as 16". . .not much difference. I would make the ports 17" long and use the Precision Sound Ports: http://www.partsexpress.com/pe/showdetl.cf...tnumber=268-352 With that much power, I would spec: Ohm: dual 1 P Chamfer: no Cooling: yes +$40 Flatwind: yes +$20 Daily or SPL: Daily Extreme Lead: no Universal: yes Brian
  7. BKOLFO4
    15 BL vs 15 BTL
    IA 40.1's are nice too. . .
  8. BKOLFO4
    15 BL vs 15 BTL
    The Fs of the 12" BTL is 40 Hz, the Q 28 Hz. But you actually made my point even stronger. . . There is a lot more to look at when selecting a sub than "Do I have the maximum amount of power this sub can handle, because if I don't, it is not worth buying." Brian
  9. BKOLFO4
    15 BL vs 15 BTL
    It is not just buying subs that you can push to the limit. . . BTL and BL's almost have to sound different just because of the way they are built. I wish I had a set of BL's just for comparison. According to the specs, the BTL is just shy of 3 dB louder with 1 watt input. . . It is about more than if you have enough power to "over power" your sub. The point I am making is that 1000+ watts will power pretty much any sub, and I personally have a pretty good feeling I would choose the BTL over the BL if I was not on a budget just for the way they perform.
  10. BKOLFO4
    20.1 question
    If that is .35 DCR, you should be ok (more like .5 ohms impedance + rise). I am now running my 40.1's at .35 DCR with no problems, and as I understand it the 20.1 handles low ohm loads much better than the 40.1. Brian
  11. BKOLFO4
    15 BL vs 15 BTL
    Because we all know underpowering a sub will blow it. . . . j/k
  12. BKOLFO4
    18inch BL new box
    If he has 20 ft^3, would you start that big for a single 18? I am just curious. . . .
  13. BKOLFO4
    15 BL vs 15 BTL
    I have run MT's and BTL's in the same enclosure. . . .The BTL's sound better and run way cooler playing music at high power for long periods of time (with the cooling option).
  14. BKOLFO4
    18inch BL new box
    I have never built a 100% all out SPL only setup - Even when I wanted it to get loud, I still wanted to be able to play music. For my original dual 18" setup, I was space limited, so I went with the largest box I could and then tested port tuning frequencies from 30 to 63 Hz by pretty much cutting 1/2" at a time off of my port (yes the box got slightly larger each time.) Took readings - measured SPL, the actual impedance, true tuning frequency, and power output from the amplifier from 30 to 65 Hz for each port length. I then graphed all the data (tuning, box size, power, and output) and determined the length I wanted the port to be. My latest setup is just 12 ft^3 tuned to 35 Hz with 200 inches of port area. Wanted something that would get loud and do an awesome job of playing music. You can download something as simple as the spreadsheet on DIYSubwoofers.org and play around with frequency response of different boxes at different tuning frequencies. I use that spreadsheet a lot for designing boxes. . . Brian
  15. BKOLFO4
    new md2 differences
    With connections along the side is the "06" model, with connections on the end is the "07" model. Different designs. . .07 model is closer to the AX line. http://www.soundsolutionsaudio.com/forum/i...?showtopic=9312 Both are good amps.
  16. BKOLFO4
    15 BL vs 15 BTL
    I would. . .
  17. BKOLFO4
    Box size
    That is not far off from where I am with my BTL's Is that NET volume after port and driver displacement? You could build a 2 piece box and connect them together after they are in the car. I have done that a couple of times. . . Brian
  18. BKOLFO4
    The eXtremes of what to tune the Fi lineup
    For a daily driver that you are going to compete with (looking for best SPL, but want to play music), I have found subs can work tuned up to 40-42 Hz, but definitely need the subsonic filter set correctly and you will find songs that are not as strong as they are with a box tuned to 35 Hz. If you are not going to compete with the system on a regular basis, I would not bother tuning above 35 Hz. For SPL only, there really is not a limit to the tuning. Music may sound terrible, but if the subsonic filter is set correctly, you will be ok.
  19. BKOLFO4
    whats best??
    (2) 12" Q's would be my vote, but that is enough power for a 15" BTL too. For the Q, you can get the BP option if you want, but not required with the power you are running. You would need dual 1 ohm coils. You wire the coils on each sub in series (making each sub 2 ohms), and then parallel the two subs making the final impedance 1 ohm. For the BTL, I would add cooling, 3rd magnet, HiXmCoil, Daily, and Universal. For a single sub, you would want a dual 2 ohm sub. Wire the coils in parallel for a 1 ohm load. Brian
  20. BKOLFO4
    15 BL vs 15 BTL
    I have run a pair of MT's on less than 1800 watts and they sounded great. I have run (4) BTL's on a single 40.1, sounded awesome. Nothing wrong with only running 1200-1400 watts to the BTL if you can afford the extra $$$ for the subs. Awesome sounding sub, and will get even louder when you decide it is time to buy more power Brian
  21. BKOLFO4
    Box size
    If that is all you can get, use a 12" BL.
  22. BKOLFO4
    18inch BL new box
    Use the box you have now to determine where your peak is in your car. You can change the port tuning and test (repeat over and over) and see what works out best. For SPL only, the box size and tuning work together to make the most SPL - the biggest box you can fit is not always the best solution. Testing, testing, and more testing. Brian
  23. BKOLFO4
    IA 40.1
    Mine are running at 0.5 ohm now. . .man they make a lot of power. . .
  24. BKOLFO4
    Hello from Irving, TX
    Hi!!! I am up in Denton, Tx. BTL - daily beater you want third slug, long coil, cooling, universal, and daily. Brian
  25. BKOLFO4
    Bl 18" BOX
    4" x 21.5" is enough.
