BKOLFO4
BANNED
    1,685
Everything posted by BKOLFO4
  1. BKOLFO4
    port help with a Fi Q 15 with BP
    I just use: http://www.carstereo.com/help/Articles.cfm?id=31 As far as end correction - It seems to work with ports up to 3-4" wide, but beyond that the extra wall does not have as much effect. I never take more than 2" off for end correction on a slot port. Brian
  2. BKOLFO4
    I come up with the port being too long. 36" is closer to 29 Hz. edit - you subtract the 1.75", not add it, that is the difference. The effect length increases with a slot port, which means you can subtract it from the actual length. tuned that low is going to gain bottom end, but lose some output where most song's have the strongest bass. Can you post up full dimensions of the box for us to see?
  3. BKOLFO4
    Ever wonder what clipping really does??
    I remember that test - awesome for trying to explain to people that as long as you do not go beyond the thermal or mechanical limits of the driver, clipping does not blow them. That link does not work for me. . .
  4. BKOLFO4
    Impeadence rise?
    I don't think they can.
  5. BKOLFO4
    Melting glue
    Scott told me there is wax in the lead wire that is melting. . . Brian
  6. BKOLFO4
    Havoc magnets ???
    Not likely a problem. The coil is gapped to the top plate, not the actual magnet. There is plenty of clearance between the coil and the magnet. The magnetic force in the gap is not going to be affected by that much of a shift. . . Brian
  7. BKOLFO4
    Dealers
    I texted your dealer and told them you would be sending a PM. . .
  8. BKOLFO4
    amp for 12" BTL
    Man, someday my son will be on a forum asking this same type of question Is you dad going to upgrade his electrical system to? Does he have a budget?
  9. BKOLFO4
    Impeadence rise?
    It really is not if it is in static position, it is if you have DC current or AC current. DC current, the resistance is the coil's DCR, AC current is the impedance with the 'Z' portion as you described.Apply DC (like a 9 volt battery) to a coil and the cone will jump, but the coil resistance is still the DCR. But the measured impedance at a given frequency will be different for a driver in and out of the box. Every time I have ever measured it, it is always higher with the woofer in the box. . . Do you not agree?? Brian
  10. BKOLFO4
    ia 40.1 ever again?
    I started a build log for the van. . . Will post pics as we get going! Brian
  11. BKOLFO4
    Check Out What UPS Delivered Today!!!
    I could not tell from the pictures. . .It looked like it was just the standard 5 layer birch. . . BTW - Box looks awesome! Brian
  12. BKOLFO4
    That looks like standard Birch Plywood. Works great (I have used it on multiple boxes), but to really be as good as MDF, I think you need the 11 or 13 layer void free Birch plywood.
  13. BKOLFO4
    2-dual 1ohm BTL 12s....2500+rms or 3500+rms
    So if it comes down to money, sounds like you have to make your own decision. . . If you are asking which one is better. . . .let's just say the BTL will take 3500 each without any problem. . . As far as actual output, if you go from 2500 watts to 5000 watts, you will gain 3 dB if you are really lucky. 2500 to 3500 will be a noticable difference to the ear. Worth the extra effort, once again you have to decide.
  14. You are way over driving that sub if you have killed the tinsels twice and burned a hole in the spider. . .Even if it was still in warranty, your misuse more that likely would not have been covered. Brian
  15. BKOLFO4
    Need some references..
    Go Nick Go!!!!
  16. With the top pic, you might as well just have one relay, since the same current will pass through both. With the second option, the relays are in parallel and the current will be divided between them.
  17. BKOLFO4
    having issues paying thru paypal
    Use thick paper (like manilla folders) for shims. Cut to fit inside the coil. Keep test fitting until it is tight. I even use sheets of paper after the manilla folder pieces are tight to make sure it is a good snug fit. Just don't get it so tight you cannot pull it back out after the recone is glued in.
  18. BKOLFO4
    Pics of Ascendant/Sundown System
    Man I have looked at these pics 7 times today. . .That is just nuts. Wish I was close enough to see it and hear it in person. Brian
  19. Let's try it. . .I would love for my Mayhems to look like Havocs. Does the Havoc have the inner 3" cap over the coil?
  20. BKOLFO4
    Who knows their Projectors??
    Can you point me to a few of those reviews? The company I work for is a VERY large OEM distributor of Panasonic products, so I can get the AE2000U for quite a bit less than the 1080UB. The main reason I was leaning toward the 1080UB was for the brighter output. Evan's review said the AE2000U loses picture quality over 100" (or too far from the screen) in cinema mode. . . Thanks! Brian Sorry to jack the thread
  21. BKOLFO4
    Man it is awesome! Where is the video???
  22. BKOLFO4
    Wow man. What subs are those? I don;t even feel like building my van anymore
  23. www.avsforum.com is another good source. I built one for my projector, but the newer processors in the projectors actually do such a good job decoding that I am not even sure if I will use it in my new HT. Brian
  24. BKOLFO4
    Tweeters
    Scott is building a nice set of tweeters under the Ascendant brand name. . .
