caintrain
Members-
66 -
Content Type
Profiles
Forums
Gallery
Everything posted by caintrain
you email him? yeah i did, prett sure to recone the e8's i have to get the updated parts coming out for the new model...still gotta loook into it more STUZY, dbl baffle? Flush Mount? Port forward subs forward...sorry i keep missing your calls...
need info on OHM 's for Fi BTL . questions about future system. an
caintrain replied to swagger_wagon468's topic in Amplifiers / Head Units / Processors / Electrical
Problem is......You can't do it on a budget. If you start off with a smaller system and you make mistakes( which you will being your first one) then they are cheaper fixes. Also when you plan TOO BIG on the first one and you skimp on the necessary small things, then it will not be what you want in the end. TAKE THE ADVICE, START SMALLER....A BL on 1000 watts sounds great and it is a way above average system! -
STU!!!!!!!!!!!! What are all of your max dimensions and I will get started on a design.
Will Someone check these enclosure dimensions.
caintrain replied to caintrain's topic in SPL & SQ / Fabrication
Yeah The Box is not for me...It is for two AA mayhems so im thinking double baffle and probably some dowel bracing... the reason for the dimension check was I made a Box calculator in Excel and wanted to check it for accuracy for future box designs. Thank you very much for checking it for me. -
Wood Thickness 0.75 Height 30 Width 38.5 Depth 15 Sub Displacement 0.42 Port Height 28.5 Port Width 3 Tuning Frequency 32 Port Length 29 3/16 I get Around 6 Cubes at around 32 hz, after sub and port displacement...i just want to be sure they are correct. thanks.
When Calculating port length, How can you enter the box volume after port displacement, without knowing what the port length will be. Or do you put in what you want your box to be after the displacements and then design a box that takes this into account. For example, if you want a box to be 4.5 cuft. after displacements you would use this to calculate the port length. Then after you have that you would calculate the port displacement lets say is .5 , SO you would do .5 + 4.5 to get 5 cuft., then design a box that is five cuft before port displacement and use the port length that was calculated to get the desired tuning? If someone needs further explanation please ask. Thanks.
it's 'around' 3.5 cubes, 28 x 16 x 20 Port length? Width? 24" long 2.5" wide. if i'm wrong please let me know. lol Doesn't sound right...I don't have time to do the calculations right now, if I check later and noone has done them then I will help you out. Sorry i couldn't do it right now....
What are the dimensions....doesn't look like 3.5 cubes, especially after port and sub displacement.
how much for 6 yards sent to 49058.....what color choices do you have?
I Like the new chargers....my cousin just got one a while back and loves it. His is all stock and it looks great, it would look amazing with after market rims. Charger
How do you calculate the kerf port so the length matches what you need it to be, and how do u get it to curve the way you want??????
This is what im looking for....now just to clear it up....if i have a front piece that is supposed to be 25" long, a port piece that needs to be 20, and the kerf will add 4.71 inches, the strait board i need to cut for this will be 25+20+4.71=49.71" correct? or am i off track?
ALright so i want to do a kerfed port on my next box... i read a thread and i am almost ready to give it a shot. However i have one question. when you do the kerf, do you use the port piece to kerf and then attach it to the front piece on the box or is the port piece and front piece one seemless piece with the kerf in it? if this doesnt make sence i will try to expalin better.
when using sketchup is there a way to enter the length of the arc you want to use...i can draw arcs but im not sure how long they are or how to tell how long the straight piece of wood would be before kerfing.
Thanks that helps alot.... I read in the other thread that for a 3 inch radius you add ~4.7 inches to the calculations...so say my port piece is supposed to be 20 and the front piece is supposed to be 25, then i would add those up and cut a piece of mdf at 49.7 inches and then kerf where i need it to bend?
I am Trying to come up with some designs for a couple amp racks, however I'm lacking creative touch I have seen a few nice ones on this site but just wanted to see if people would post some pics of theirs to give some ideas/show theirs off. I will probably be using mdf to make mine but I would like to see some of all different materials. Thanks.
WOW! i have that same head unit, do you like yours...i like your setup, couldnt even tell it was a blow thru, very clean.
I like it...what type of vehicle is that in?
I would really like this to be 32, how can you drop the tuning without a serious adjustment to the port length?
Can someone check these calculations? Height:20 Width:38 Depth:14 Port Length:25 1/8" Port Width:3" These are externals. Thanks for any help
Not my box...but i am assuming he is going to want a double baffle as long as we can get it on one sheet of mdf...
Thought it would be nice to have a bunch of pics right in one place for everyone to show off there set up/ gain ideas for future set ups...
is that 4.8 without port volume displacement... the reason Im checking calculations is because i worked it out and got around 32 hz with a 3.66 internal volume...thats figuring for port displacement and for 15"btl which is .21 ft^3. Thanks for your help guys just want to be sure im accurate
