mrjohnsonjr
New Members
    13
Everything posted by mrjohnsonjr
  1. So Im new to this but i have an 86 chevy suburban i want to have it banging harder than anyone eles in the hood. so im planing on getting two fi ssd 18's and i dont know if i should get a sundown saz 2500d or a saz 1500d please help i just have stock battery and stock atl will i need upgrades if so what do you rec
  2. So half say 2500 and the others say 1500 v2 still confused but thanks all one more question if i go with the 1500 v2 will i need electrical upgrades?
  3. We can't tell you what exactly you will need because we aren't there doing it for you. But here's what we can recommend. If you run the saz-2500d at 1 ohm you will need electrical upgrades. Here is what you should try in order. Big 3, Battery or Batteries, High Output alternator. The saz-2500 draws a lot of current. You need power to make power. With the Saz-1500d you will probably need to do the big 3 and have an extra battery. Anyways, 2500 watts is a lot for those subs. SSDs are rated at 800 watts and with that amp you'll be giving them 1250 watts each. It may take it, but then again they may not. It really all depends on the install. Since you said you are new, I'd personally play it safe and go for the saz-1500d and run it at 1 ohm for 750 watts to each sub. make sure you get Dual 1 SSDS so you can wire to 1 ohm. Hope I helped. So everyone tellin me if i get the 2500d i will blow the subs wired at one ohm i thought them subs where beast that they where underrated and could Handel atleast 1300 watts what about if i find one of them discontinued 2000d's i dont want them to only get 750 watts and be underpowered so whats a good range to keep them in watt wise Give them rated power. And use smaller font size. If you want to run more power then quit being cheap and buy the BL or BTL. And to go along with this step up of power, upgrade your alt and get a few batteries for the back. I'm giving you good advice, DAWG. thanks man i really appreciate all the info.... and by the way we dont say dawg any more its doggie now
  4. I would get at minimum a SAZ-2500D and 2 Batteries thanks the the advice. two batteries meaning two additional and the one under the hood right?
  5. So everyone tellin me if i get the 2500d i will blow the subs wired at one ohm i thought them subs where beast that they where underrated and could Handel atleast 1300 watts what about if i find one of them discontinued 2000d's i dont want them to only get 750 watts and be underpowered so whats a good range to keep them in watt wise
  6. We can't tell you what exactly you will need because we aren't there doing it for you. But here's what we can recommend. If you run the saz-2500d at 1 ohm you will need electrical upgrades. Here is what you should try in order. Big 3, Battery or Batteries, High Output alternator. The saz-2500 draws a lot of current. You need power to make power. With the Saz-1500d you will probably need to do the big 3 and have an extra battery. Anyways, 2500 watts is a lot for those subs. SSDs are rated at 800 watts and with that amp you'll be giving them 1250 watts each. It may take it, but then again they may not. It really all depends on the install. Since you said you are new, I'd personally play it safe and go for the saz-1500d and run it at 1 ohm for 750 watts to each sub. make sure you get Dual 1 SSDS so you can wire to 1 ohm. Hope I helped. So everyone tellin me if i get the 2500d i will blow the subs wired at one ohm i thought them subs where beast that they where underrated and could Handel atleast 1300 watts what about if i find one of them discontinued 2000d's i dont want them to only get 750 watts and be underpowered so whats a good range to keep them in watt wise
  7. So everyone tellin me if i get the 2500d i will blow the subs wired at one ohm i thought them subs where beast that they where underrated and could Handel atleast 1300 watts what about if i find one of them discontinued 2000d's i dont want them to only get 750 watts and be underpowered so whats a good range to keep them in watt wise
  8. For the high output alt how many amps will it have to be and what size battery would be good? what companies do you recommend?
  9. Wishlist Sax200.4 Saz2500d 2 Fi SSD 18 all in 86 suburban
