tsealsut2010
Members
    67
Everything posted by tsealsut2010
  1. tsealsut2010
    new install
    im at school i have no pics right now when i get home and have some time ill add some pics
  2. tsealsut2010
    blown amp
    i had the same problem for awhile with my merlin md41, and i poked around with a DMM and found it was the fuse. i looked at the fuse and couldnt see much wrong. it was a hairline fracture on the fuse that messed everything up, my guess is check that first.
  3. tsealsut2010
    voltage
    i have a 2001 honda accord. and ya i will get it checked out. i just got out of servicing it, and im surprised that they didnt check that out as well. thanks for your help. i have a ax1000de and a merlin MD41 and im pretty sure that they will take up to 16.5volts, or higher im not sure.
  4. tsealsut2010
    voltage
    ok so i talked to my friend and hes getting around 13.5 volts to everything in his car. i thought i was only getting about 14, but when i checked it with my DMM im getting something steady between 17.2 and 18.6 is this overkill or is that good?
  5. tsealsut2010
    us amps website
    im not to fond of the site either. i think they should lose some of the flashy stuff, and get more specs on the amps, and some much better navigation. i hate having to wait 30 seconds every time that i want to see an amp, but i do love us amps thats for sure.
  6. ok i just got a new 9855 with 4 volt preouts and a used merlin m41 from flakko, and i go the 9855 to work, but when i hook up the amplifier, nothing, not even the power or protect light came on, but then today outta nowhere when i turn on the car, i hear this semi loud click noise, and the amp turned on and i could listen to music, but wasn't very loud, even at 20 volume. it then proceeded to shut off again, and now has no music coming from the speakers, and the amp's lights (power/protect) are off as well. i had this same problem with the last amp i had, before. and im sure when i put that one in it will have the same problem. anyone have any ideas? and i have speakers in my rear deck that are connected via the h/u, and they dont play either. answers, suggestions, comments.
  7. tsealsut2010
    amplifier not working
    its always the flippin fuses i swear. and taking the paint off the grouds helps alil too, and that is why you never let cartoys do your wiring when your 16. aite well everything should work now. thanks for your help.
  8. tsealsut2010
    good pair of components
    im looking for a good pair of components for an SQ install 6.5" for around $200 shipped, going at around 65w at 4 ohms or 180 at 4 ohm. do yall have any suggestions? and if so where to purchase them as well, im going 2 be playing them with a US Amps merlin md-41 amp.
  9. tsealsut2010
    ya I AM A check all that tomorrow when i get off of work. the remote lead is a prbable cause, we just twisted and electrical tape. I AM A solder it all together then use a solderless crimp terminal to get all three wires. and if that doesnt work, then its either the power wire, or the amp itself, but my guess is the power wire.
  10. tsealsut2010
    the power or the protect light would still be on if it was the h/u though wouldnt it?
  11. tsealsut2010
    ok so i got the back speakers to work and i tried the amp on my other wires for the sub amp. still nothing. where gunna check all the wiring sometime this week probably with a DMM and ill post the results and see what's going on with everything. i hope its just wiring...
  12. ok i just got a alpine cda9855, and the preouts say 4 volts. i am going to be using a us amps ax1000de and a us amps merlin md41, and the input gain on the ax1000de is 150mV to 3 volts. and the md41 i dont have the manual on. so my question is. will a 4 volt preout work with this amp, and if anybody knows if it will work with the merlin as well. also what exactly will the difference be between 2 volt preouts and 4 volt preouts. becuase im pretty sure 4 volt is better. thanks
  13. tsealsut2010
    preout voltage
    ya but i dont really have the money right now for even a decent eq, i will in the future though, and when that happens i will need it. i got this on the cheap and sold my old 9851 for a good price, ended up only costing me a net total of just over 30 for this one.
  14. tsealsut2010
    preout voltage
    i really dont needa listen to the music louder than 23 anyway so im not to worried. ive had a 9851 for about a year or so n i liked it alot. i just want the mx, and a display that is more readable. so im not to worried about that.
  15. tsealsut2010
    preout voltage
    ok cool sounds good. lol at 34. i felt freakin stupid asking but i wanted to make sure. thanks
  16. tsealsut2010
    ax1000de question
    i just got an AX1000de, i dont see any internal fuses so im guessing that im going to have to do an external fuse for it. my guess is a 100 amp fuse . do any of yall have any input on placement of the fuse, the fuse size, and where i could get one, and a fuse holder for a reasonable price. thanks
  17. tsealsut2010
    ax1000de question
    ok it says in the manuel 100 amp fuse externally. hard to find though. its tiny in the booklet. well where should i place the fuse and fuse holder is what im asking now. and where is a good place to get them
  18. tsealsut2010
    best sql vehicle
    alright i have a 2001 honda accord coupe, and am looking into buying a new ride. im not sure whether to be looking into another trunk installation, SUV, or hatch. I have a diamond audio d915d2, a us amps AX1000de amp, alphasonik components with a us amp merlin md41 powering them. i am looking for basically a realiable wehicle that will be the best for a LSQ system. looking to pay around $20k or less, or if i should stick with the car i have now. dont have an enclosure yet, but will build for respective car. (if keeping the accord i will be making a fiberglass corner enclosure), and i may also be doing this for any other car i may purchase. something sporty, and that looks good, i was looking at a supra, but knows. thanks
  19. tsealsut2010
    best sql vehicle
    do any of you all like this car its one that i found at a local dealer in my city. heres the link. new car on autotrader
  20. tsealsut2010
    How old are YOU?
    18, 19 in sept
  21. tsealsut2010
    thanks yall, ill look into all of that, i have some alphasoniks right now but i dont think theyre gunna b as good as i want them to be. whenever i finish my install though I AM A post it up on here and ill see wut yall think. im makin kicks to put em in. either that or a custom door panel.
  22. tsealsut2010
    which amp do yall recomend?
    hey yall im looking at purchasing a US AMP and want to kno which one do yall recommend: this USA 400 http://cgi.ebay.com/US-Amps-USA-400-2-chan...1QQcmdZViewItem or this DE1000 http://www.speedsound.com/product.asp?specific=jnirnmdng am mostly interested in an AX1000DE if any knows where to get one but for now which do you recommend.
  23. tsealsut2010
    ok im in a dilemma, i am trying to figure out which box to use for a d915d2 being powered by a US AMPS ax1000de at 1 ohm. I have run some figures and made some graphs using WIN isd and have them for you to look at. i am going for the best SQ but spl is an issue to. i do like to thump. if anyone can help me analyse this information and decide which enclosure you believe to be best for me (vented, or sealed). the went will be a square 3x16x39, and will be following these specifications http://www.diamondaudio.com/products/pdfs/...Vented%2005.pdf it is already facotred in on the graphs and the other specs are here http://www.diamondaudio.com/products/pdfs/...ch%20Sheet2.pdf the pics should be up soon.
  24. tsealsut2010
    thanks, ill look into it.
  25. tsealsut2010
    do you think that this box would be the best for me, it is the manufactures suggesttion. http://www.diamondaudio.com/products/pdfs/...Vented%2005.pdf
