On3Hundr3dProof
SSA Supporter L1
    360
Everything posted by On3Hundr3dProof
  1. On3Hundr3dProof
    3500 watt electrical
    after idling it usually is around 15.0-15.2
  2. So in my next build I'm going to be running around 3500 watts probably a bc3500. For my current electrical setup i have a dc 270xp alt the big 3 and a d5100r in the front. Voltage @ idle is 15.2v. If i run 2 runs of ofc 0ga to a deka 9a31 in the back then one 2ft run of 0ga from the batt to amp is it going to be enough to to keep me above 13v for the most part or will i need a second 9a31 in the back. I plan on getting a second one later on anyway but would it be necessary? Thanks.
  3. On3Hundr3dProof
    Thats cold. Ive had the alt in about 2 weeks. Itll go to 15.0 if its warm and its sitting idle for a few min.It takes a while to get my truck warm up here though this time of year. I havent had any problems so far though.
  4. On3Hundr3dProof
    Voltage at idle is usually between 15-15.4 Its the alt.
  5. On3Hundr3dProof
    '10 Nissan Frontier / SA-8s
    yep. alt shipped out yesterday got my enclosure build in the works gotta get the rest of my electrical done then ill be looking for a 3.5k amp.
  6. On3Hundr3dProof
    Update: starting on the pieces for my new build. Ordered a dc 270 xp and picked up my new drivers..2 Memphis MOJO cm15d4's
  7. On3Hundr3dProof
    mojo coil rub
    Yeah bigjon but its the new style cm and i got the motors and carts off caco and the guy lives in my town so hes gonna help me go through elite where he got them if i cant fix the rub
  8. On3Hundr3dProof
    mojo coil rub
    I just put a new CM MOJO "catridge" on a motor and im getting some coil rub. I did a second one and it turned out great but i remounted the catridge a few times on the first one and it keeps rubbing on the same side inside the coil. I think its slanted not off center. I mounted some old cartridges i had on the same motor and didnt get any rub so im pretty sure its the new cartridge. Any advice on a fix?
  9. On3Hundr3dProof
    mojo coil rub
    It came from Elite audio in sc
  10. id say a 250a alt big 3 2 run 0ga to back and 1 d3400 up front 2 d1200 in back
  11. On3Hundr3dProof
    Power loss?
    1.what load are you putting on the amp? 2. Unhook the 8
  12. On3Hundr3dProof
    Nissan Frontier 2.5L Alt
    ordered one from dc talked to them about it and the 09 alt will fit and it should ship within a week.
  13. Ive been looking at DC alts for my truck and they go from 2005-2009. The 2010 is the same gen and engine as the 2005-2009 im guessing they just left it off the list by accident just wondering if anyone knows for sure if it would work or wouldnt for some reason. thanks in advance.
  14. On3Hundr3dProof
    Do i have room
    its possible but i'd think you could get a better build with smaller drivers.
  15. On3Hundr3dProof
    Magazine Ads | Built Today
    looks awesome!
  16. On3Hundr3dProof
    clueless in orlando
    good driver choice ,but also take a look at the icon.
  17. On3Hundr3dProof
    new system, need advice
    Yeah now you need to find a more powerful most likely more expensive amp. if your doing a 2 driver build use d4's. also if your gonna go with 750-1000w per sub i'd stay on the smaller side of enclosure volume.
  18. On3Hundr3dProof
    Why do you say this lol?
  19. On3Hundr3dProof
    Reverse Mounting Subs Question????????
    if your inverting both you can either reverse the polarity on both or leave them both normally as long as they are in phase. I'd try both to see what sounds better in a particular build
  20. On3Hundr3dProof
    can your electrical support a .5 ohm load? if not youll need to run it off of a 2 ohm load or swap for d4 coils
  21. On3Hundr3dProof
    options for my next build
    Looking to start buying the pieces for my next build and im fairly sure im going to be using a bc2000 to power it but as far as drivers im pretty split between a few options. I want to be able to get really loud at around the 30-33hz area and really loud period but no a complete loss of musical ability. Going to be a daily driver build. Mainly been looking at either 2 15" ssa icons, dc level 4s, fi bl's or 4 sa-12s. Im leaning toward the sa-12s right now. Any advice would be appreciated.
  22. On3Hundr3dProof
    sub cutting out
    hey guys. i know a buddy of mine whos got an RE SXX on an SAE-1200d 220a OEM series dc power alt 2 out of 3 big 3 optima yellowtop and 0ga to the amp and hes having issues with his sub cutting out randomly. the amp isnt going into protection and when it cuts out its only momentarily. i noticed he was only running one set of 12ga from the amp to the sub and told him he should step that up. my only other thoughts would be a ground problem but im not sure what else it could be. any advice would be appreciated.
  23. On3Hundr3dProof
    sub cutting out
    gain is at half. there may be a voltage drop but i cant tell you by how much..hes trying to get a digital voltage gauge
  24. On3Hundr3dProof
    CRX part deux with Gcons
    looks good man. nice job on the door pods.
