havok13154
Members
    45
Everything posted by havok13154
  1. ok my friend will build me a box in his wood shop but i need to get him plans. SI 15 MAG, ported. what do you think of the aeroports? is it worth it for only $25 extra? most people use 2 of them at $12 each. power will be a hifonics ZEUS 1000D 1000@1ohm it is a lexus 2002 es300. should be the same as the new camrey. people have put 2 15 in there before with a almsot bent box. i only need 1. the red strap is what i will be using to hold the sub in place, i would also love there to be ehough room to put my trunk battey next to the box. it is 6.5 inches wide demetions are THANKS FOR ALL THE HELP I AM FINALLY BUYING A SUB TO FINISH MY AUDIO SYSTEM AFTER 2 YEARS!!!!!
  2. havok13154
    getting a SI 15 MAG, box help
    i posted in the SI forum and i got a answer the next day. i got my plans. thanks though
  3. havok13154
    building a box for a 15" MAG
    what do you think of this grill? will it clear? http://cgi.ebay.com/1-SOUNDSTREAM-15-GRILL...1QQcmdZViewItem
  4. ok my friend will build me a box in his wood shop but i need to get him plans. SI 15 MAG, ported. what do you think of the aeroports? is it worth it for only $25 extra? most people use 2 of them at $12 each. power will be a hifonics ZEUS 1000D 1000@1ohm it is a lexus 2002 es300. should be the same as the new camrey. people have put 2 15 in there before with a almsot bent box. i only need 1. the red strap is what i will be using to hold the sub in place, i would also love there to be ehough room to put my trunk battey next to the box. it is 6.5 inches wide demetions are (IMG:http://members.cox.net/havok/trunk.jpg) THANKS FOR ALL THE HELP I AM FINALLY BUYING A SUB TO FINISH MY AUDIO SYSTEM AFTER 2 YEARS!!!!!
  5. havok13154
    JL w7 12" vs SI D2 12"
    only thing that sucks it that only one grill will work for the sub. I want a SAFE sub. I have a lot of crap in the trunk at times. any other grill work for the 15" mag other then this one? http://www.partsexpress.com/pe/showdetl.cf...tnumber=260-444
  6. havok13154
    damn i really want somehting for protective. when i get it i'll mesure it and dubble it and then if i can make a baffle around the sub then get the standard one but it will be rasied.
  7. havok13154
    OMG thanks so much. when we build it, i'll try and get a GOOD pic for you. how was this done cad? or a program for boxes. did you screws on top where the port was? 3/4 mdf is what i want to use. so how did it hit? with how much power? will this fit over it and not let the sub hit it. http://www.cardomain.com/item/RTEGP15 thanks a lot, i owe you one let me know if i can help you with anything. fixed the pic for you
  8. havok13154
    that is the air hole to the car so the bass travels. that sub is such garbage
  9. havok13154
    $25 is worth it to make it easy. if anyone has built one for this sub i would love to see the plans and how you like it.
  10. havok13154
    thanks for the input. i'm sorry but i can't afford to buy everything i want to test it all. that is why i joined this forum to get help.
  11. havok13154
    that is what i wanted to know, how they stack up. i don't want to have the same system as everyone else. that is why i want something else, but better is also nice. i did search for 12w7 and i got a lot of stuff but no one seemed to give the answer i was looking for. i wanted a stack up, not a jl is better or si is better. like witch is louder, sound qualtiy, area of affect (how far away people will hear it). if someone knows that i would be VERY happy. i'm getting a SI anyways i just want to see if i can brag about it.......
  12. havok13154
    1 or 2, 12" D2 mags?
    well if i do one i wont add one i want to build ONE box. if i get 2 i'll upgrade the amp later. also i will be using 750x1 at 2ohm so that is 375 each, that seems too low to me. i think one will be enought.
  13. havok13154
    i have a 2002 lexus es300 same trunk and the new camrey i think. i'm thinking ported, tuned to somewhere around 28 or so. i have no idea really i'm not a box guy at all. same tuning if i use 2? i have a hifonics zues 1000d that does 1000@1ohm i want clean sound but i want lots of bass when the right song comes on so i can crank it. would it be better to get 1 or 2. if i get 2 can i get a better amp in lets say 6 months? us amps 1500@1ohm? i was going to get 1 but i see people posting about 450 watts on 1. will 1 sound cleaner then 2 at 1000@1ohm? how muhc louder will 2 be then 1? sorry for all the ? but i want to amke 100% sure what i'm doing. can i buy box plans from someone? my friend has a wood shop so he will build it if i give him plans
  14. havok13154
    that shines a new light on it. 2ohm means even more money. maybe i'll just do 1 and if i really want to drop the $1500 on a amp and another sub i will. i was hoping to get another one and spend about 500 on a 1500x1ohm. maybe i'll do some research on a .5 stable amp. thanks for the input if anyone has some more let me know.
  15. havok13154
    well if i get one and run it at 1000 and get another then one will be worn at 1000 rms. if i get another I'll have the money to buy a new amp so each will get 750. but one will be used at higher so will the new one sound as good as the used one? used one will have had 1000 and now have 750 as the new one. ALSO i have 2 10" planet audio big bangs now(they are old maybe 5 years). i assume the SI will put them to shame. that is why i was thinking 2 because i got 2 now but they are 10". the SI will replace the planet audio
  16. havok13154
    if i do 2 now they will get 500 watts each i'm keeping my amp for now as i have enough to buy 1 or 2 sub i have about $1000. so SQ will be the same. will 2 with 1000@1ohm be louder then 1 at 1000@1ohm?
  17. i am looking at the Ascendant Audio Arsenal or 12D2 mag. i was reqamended the MAG and the Arsenal by another. i have a hifonics ZEUS 1000D 1000@1ohm, 750@2ohm 500@4ohm. i want to run it at 1ohm if i can. i know the mag is perfect for the amp but what about teh arsenal. SQ means sound quility but LSQ means??? sound quility loud?
  18. havok13154
    Ascendant Audio Arsenal VS 12D2 mag
    as of right now i'm getting a mag not sure on 12 or 15 yet.
  19. havok13154
    only seen someinfo on it. it is on the level at or above the RE XXX. i think the mag is cleaner though. is showrides the only place to buy the mag?
