RXdriver11
Members
    126
Everything posted by RXdriver11
  1. RXdriver11
    How to wire multiple amps per coil
    Well you can strap em and run them that way. But you need to make sure you sub wont be wired too low for the amp to handle. And you can also run each amp to each coil, but that would only work if you sub has 4 coils. We need to know the equipment to give you more input.
  2. a 12"x12"x5" cube of 6061 would be absolutely ridiculous to try and buy... We just turned in our chips and I think we got .91/lb which is pretty good, but that's for 6061 AL.. Is that a yes for me? Yes, that is a yes for you... We are 100000% going to make this housing.. Are you guys still gonna need my car cause ill get it there bright and early if so?
  3. Small thread jack but wondering if the lex is ever gonna run dc power?
  4. RXdriver11
    What specific equipment are you trying to do this with?
  5. Best simple explination ive ever seen on hunting electrical problems. Good shit MECHMAN @kryptonitewhite where are you located(im on mobil so i cant see)?
  6. RXdriver11
    Wassupp peoples !
    Welcome to the forum.
  7. RXdriver11
    Gotta get that Boom Boom Boom.
    More pics! I cant wait..
  8. RXdriver11
    What's a cool team name for...
    Team Funkypup..
  9. RXdriver11
    Need Nathan's advice please
    At least 1 more run of + and - from the front.
  10. The closer to the battery the better. If a short happens before the fuse you will be buying a new car.
  11. RXdriver11
    argent audio review
    Honestly, I wouldn't delete the thread. Some of the other vendors need take note that THIS is how you quickly and professionally resolve an issue with the customer. Outstanding customer service. Kudos to you Andrew. X's 2 on not deleting this thread. I have dealt with Andrew on my last build and my current rebuild. He is a great guy, even took time out from a night out to dinner just to contact me about my box. And this will show potential customers how good of service you provide, and how many satisfied customers you have..
  12. RXdriver11
    250XP A;ternator
    I wasnt saying you made a mistake you guys are A+ in my book. Im just really impaitent.. but i just sent you a pm..
  13. That one is.. no wait that other one is. Dude if you wanna stay on the cheap side just buy the cheapest one.. no brainer..
  14. RXdriver11
    250XP A;ternator
    Maybe kyle or rob could be able to find some time to get a lexus rx300 in there shop before the owner starts getting the last of his new equipment.. lol
  15. RXdriver11
    Head Unit Problem!!
    And what is the car?
  16. RXdriver11
    Head Unit Problem!!
    What about your radio harness did you run new wire or tap into factory wires?
  17. RXdriver11
    Head Unit Problem!!
    When you did the light install did you wire any of the light wires to a wire that has a function on the radio, or did you plug into factory light harness?
  18. RXdriver11
    Head Unit Problem!!
    Did you tap any wires for radio while installing the hid's?
  19. RXdriver11
    Best place to buy wiring kits
    First go get some knukonceptz wire and build your own kit. Second does your h/u only have 1 rca output? It should have a set for front rean and sub. Thats what you will need for the componets amp.
  20. Hey what part of cali are you in?
  21. RXdriver11
    bolt terminals
    Aluminum is the cheaper way to go too.
  22. RXdriver11
    Kyle can you check your PM
    How about Kyle can you return my calls too? They. are a lil busy over there if you keep calling and pm'ing he will eventualy get back to you..
  23. RXdriver11
    bolt terminals
    Stainless or brass. Im using stainless but only because i got bussbars that are gonna be stainless too. Can wait to hear it bro.
  24. RXdriver11
    3/4 inch plywood ok for second baffle?
    This statement is the exact opposite of what it should be. I have laminated MDF with several types of plywood and OSB for use on baffles and never had any issues and in my part of the country it is easy to see 30-40 degree temperature changes in a matter of hours. If anything would cause cracking, that would, and none of the enclosures have had any type of failure. I never said anything about cracking im talking about mounting and having your mounting holes split. With the screws being installed and removed over again a few times. True i have seen this happen with mdf.. but t-nuts will prevent that (when properly installed). I have not found a good fix for that in plywood. Although i dont have a lot of experience with plywood in speaker boxes just that 1 experience. I do however use ply in various remodels and yes if put a screw in it and leave it alone it will hold great. But when constantly removing and readding screws it starts to splinter. And for all i know that may have been a soft ply, this box was built 10 yrs ago and i dont remember all the specs of the wood. But ill look for some photos when i head back to my folks place..
