mrbojang
SSA Supporter L1-
483 -
Days Won
1
Content Type
Profiles
Forums
Gallery
Everything posted by mrbojang
wheres the original at? also, that is hilarious. damn curbs need to watch where they're sitting!
Where is a good place to buy wire?
mrbojang replied to chainsaw's topic in Amplifiers / Head Units / Processors / Electrical
weldingsupply.com ftw -
Already thinking of my new setup...
4 15s down the line. Need to upgrade my electrical, front stage and do some deadening first.
- Show next comments 18 more
I like it man..My subs do too! Thanks!
I metered it on a crappy most likely uncallibrated audio control. It hit 145. I'm investing in a SPL Labs LCD meter so I should know for sure soon. As far as the hair trick, have to see if I can get a hold of someone who doesn't mind..Working on it.
Sorry about the weird angles. lol.
sax-125.2 can do close to that if i'm not mistaken
Has any thought been put into a 'slim' line for extreme space limited applications? I know pioneer and some other brands have some very thin subs out there.
Do you use a remote knob?
mrbojang posted a topic in Amplifiers / Head Units / Processors / Electrical
Just wondering how many of you guys actually use these things.. -
Batt Help Please!
mrbojang replied to PHATBOi's topic in Amplifiers / Head Units / Processors / Electrical
sounds like you need an isolator or identical batteries. -
Voltage drops?
mrbojang replied to mrbojang's topic in Amplifiers / Head Units / Processors / Electrical
I just sanded down the ground under the hood better. Later this week I'll upgrade the other ground.. Decided to measure my resting voltage on my front and back batteries. Front is resting at 13.0v, rears are at 13.2v -
So far I'm loving the new system but I've noticed with some songs (the loudest) and also at idle my voltage can drop down to 12v. It always jumps back up to 13.8+ volts after the bass hits... Should I be concerned? I still need to upgrade a ground under the hood, hoping that will help a bit.
Voltage drops?
Big 2. Waiting to get a bit more 0ga (should have it by tuesday) to do the engine block to frame ground... Nothing on I get 14.5-14.6 volts. -
Question About Running A Bigger Amp And Another Battery
mrbojang replied to HawkEye's topic in Amplifiers / Head Units / Processors / Electrical
If you're planning on redoing your system later with more power, you might as well get the beefiest alternator you can. go for the 270xp if possible. -
I like mine better.
So I've seen a ton of videos featuring hair tricks and I figured it'd be cool to see if my system can pull it off..Only problem is that I'm clueless how to go about it. Obviously someone with long hair is needed. I'm not sure what song would be best, or what window for that matter... Any tips for me? Is it pretty much just trial and error? Any reason my system wouldn't be able to hair trick? Does hairspray\hairgel have a negative impact on it?
Glad you're enjoying your new system. However if I may, can I offer you some advice from personal experience? 1. Annoying the cars around you isn't an accomplishment. You can do that with your horn and erratic driving. In fact it makes everyone in this hobby\industry look bad. 2. Be careful who you show your system to, and also how loud you play it around where you live. There's no reason to advertise your setup to potential thieves. Also, if you haven't yet I'd invest in an alarm at the very least. 3. Cranking the HU to 100% can send a clipped signal. This mixed with a line driver is most likely a recipe for disaster. Lastly, if you're not sure of something..Don't hesitate to ask around here. Also, we like pictures.
Trouble with Saz-1500d
mrbojang replied to nick9892's topic in Amplifiers / Head Units / Processors / Electrical
Is it covered by a warranty? At this point I would email Jacob. If it's not covered by a warranty you should contact db-r. Also even if the fuses in the amp look good, it couldn't hurt to replace them. -
You could wire up the remote to your ignition worst case. -
Where do I hook up the blender?
I assume this is normal. Just curious what causes it to make a clicking noise when turning the amp on or off?
Bought a street scenes poly urethane roll pan for my truck. Just got it today. I'm planning on getting it painted tomorrow but when I unpacked it I noticed it seems scuffed. Any idea if this is going to show after the paint? It doesn't feel the same as the non scuffed parts, a bit more rough..
Just got metered on an Audio control...Did it with music. One song (The one I figured was the loudest) hit 145.0db! The song was Plies - All Black slowed by wattz305 All the other songs we tried were in the 140-143.5 range. I went in figuring I'd be happy hitting those numbers. Around 40hz seems to be the sweet spot. Still wish I had access to a termlab though.
