matj1990
Members
    148
  • Days Won
    1
Everything posted by matj1990
  1. So to get things going I used to run 2 sa12 on a bc2000 in my 04 cavalier.. Sold car with subs went about 5 years without any subwoofer. Got into bikes mostly other week was browsing craigslist for some cheap setup to throw in the focus well ended up coming across the post about ssa opening up in norwood he'll that's 5 min from me so I headed on down. That's where I met the man Mark Lafountain and shit just fell into place I foolishly bought a dcon and sealed kaotic 10 box from him only to want more a couple days later. At this point I was using loc tapped into the front speakers ., WASTE OF TIME stock unit eq out the bass.. Mark said when he heard it something doesn't sound right and suggested I run a different input signal so I did so direct from my phone big difference ..so at that point I decided to change out the head unit .. However a day or so later I wanted more ..... Keeping in touch and talking to mark he said he had a xcon that needed a recone in the back I jumped on that deal although hesitant as I was new to reconing a sub .. One night of YouTube videos and I was sure it was going to be easy .. He set me up with a new 10" basket stickers wire the works awesome guy can't say enough a out the service I got. Took it home with a couple borrowed tools from him I got it going, let it sit overnight next day my prefab 2ft box 32hz showed up I free aired the sub all was good threw it in the box ans holy shit she bumps.... Clean tight musical however it gets down !!! I'm running an apcl1000d at .5 ohm yellow top battery and 1/0 wire. And she hits hard.. Couldn't be happier next will be big 3 then maybe later a bigger amp.
  2. matj1990
    6th order help
    looking at possibly building a 6th order box for my 10" ssa xcon.. first of all i would like to know how you figure port area needed when building such an enclosure. for a standard vented box i show i need around 35" at 30hz more at higher hz obv. if i use this Car Audio - PORT Size Calculations and Formulas for WOOFER and Subwoofer BOXES and use the bandpass option i would need a box the size of my car in order to tune it low enough... clearly theirs something im missing ? i have roughly 4 maybe 5 cubes i can work with would love to hear some input
  3. matj1990
    6th order help
    oh i have read and read and read ... ive been at this since about 5pm its now 2am. Im essentially going for as flat of a response as i can get from 28-40hz ..issue im having is it looks like i will have a huge drop anything above using winlsd .. im getting 4 cubes rear tuned 30hz front 1 cube 45hz --going for a series 6th order this looks to be a pretty decent and flat from 29-45hz only 2db difference at 36hz sorry if this is just rambling lol ive done a ton of reading trying to make sense of it all and im tired.
  4. matj1990
    6th order help
    plus it gives me something to learn and do my current box is net 2.38 31hz.. not metered seems about as loud but lower box before that was 1.78 35hz metered at 138 37hz
  5. matj1990
    6th order help
    never said i need however from my understanding 6th order would allow me to play bass notes louder with a flatter response. a proper 6th order would allow me to have box gain from say 30hz to 45hz where as a regular ported box peaks at 1 note gradually drops off. all dependent on tuning of course
  6. matj1990
    box for a 10" xcon
    After looking at some response graphs and what not doing some more research I think I have come up with a better box. Same dimensions however 3.25x12 port 40" long giving me 2.38 after port.sub.bracing displacement. And 31hz tuning. Calculating my prefab box it was tuned to about 35hz all said and done so this new box built properly should make a big difference. Anyone got input on specs ?
  7. matj1990
    box for a 10" xcon
    2012 focus sedan. currently running a prefab decent but cheap box ..in its current position metered 138 @ 37hz sealed on the windshield. fired the box forward today and noticed it wasn't half as loud this tells me my positioning is right for this car. So my question is do you think this box is working well or should i build a new box different specs i don't compete but i like loud and low this setup is pretty good for a single 10 but i think there is room for improvement would like some opinions/box ideas my max dimensions are going to be around W x H x D 30x14x27 to easily be able to fit through trunk opening which is a must as it needs to be removable when i DJ Also like to mention i prefer aero ports !! specs are as follows (W x H x D): 30" x 13-1/2" x 16" (net. int.): 2.0 cubic feet 1-1/4" Reinforced MDF front baffle 2.0 ft^3 slot-port tuned @ 32Hz
  8. matj1990
    box for a 10" xcon
    Thanks for the .02 I'll take it so looks like new box it is then anyone have input on the box dimensions above basically going with the same design and firing it the same way just adding more depth more port area and lower tuning.. Also plan to upgrade my amp to something that can run 1700 or so at 2ohm
  9. So looking for some info about amplifier and efficiency. I have a xcon dual 1ohm 10" so i can run at either .5ohm or 2ohm What i would like to know is 1500w @ .5ohm or 1500w @ 2ohm the 2ohm amplifier would be drawing more power to make its wattage because of the higher resistance correct ?
  10. matj1990
    box for a 10" xcon
    I also have bass box software but i cant get numbers to match up with that of torres when using a box of the same size ?? cubic feet does not match as well as length of port for desired tuning
  11. matj1990
    box for a 10" xcon
    so according to this calculator and my torres calculator my current port that of 2.5x12.25 is yielding me about 30" of port area which is well below the minimum of 37.28 according to this website using this subwoofers xmax http://www.carstereo.com/help2/Articles.cfm?id=31 so in trying to reach optimal port area and i would like to keep it tuned low thinking 28-30hz range this is what i have came up with so far ? obv a little over sized for the sub but i am also under powering it
  12. im currently running a 1000.1d amp at .5 ohm so probably pushing 1300 or so. So your telling me if i get an amp that will push lets say 1300 @ 2ohm its going to draw less current ? 2 ohm load would be higher resistance in my understanding require more current to produce same wattage hence the reason my amp that draws x amount of current can only produce 400watts at 4ohm vs 1300 at .5 Im assuming im overlooking something and just trying to get a better understanding as to what because at 4ohm i had no issues with electrical but now that im at .5 i had to do some upgrades. shouldn't that amp have the same power consumption? obviously not but why.
  13. matj1990
    box for a 10" xcon
    nice box .. not sure what its has to do with my post thought x4 12's big difference from x1 10"
  14. want to say ive seen these first hand !! and metered my car as a test Awesome accurate little meters and Lighting fast readings as well
  15. matj1990
    2012 focus with some bump
    metered 138db today 37hz ... building a new box tomorrow to spec as per website
  16. Building a xcon setup for 2012 focus
  17. matj1990
    SSA Dcon install photos (share them)
    I will also say that the dcon I had in a sealed enclosure was very nice sub.
  18. matj1990
    Sorry for pics being out of order .. Can't edit from phone and photobucket must change names as it was uploading
