38 -
Content Type
Profiles
Forums
Gallery
Everything posted by trinitymatt
clif designs?
trinitymatt replied to trinitymatt's topic in Amplifiers / Head Units / Processors / Electrical
thank you very much. one more amp to ask about the DD Z2. anyone know anthing? I know how Jassa is the ratings would be true real world, anyone have any thoughts about it? -
I am redoing a car that has 2 concept cc-d2400's. I'm thinking about going with 2 cdx-20a's, are they strappable? what are the full specs, S/N, etc...? Any help would be greatly appreciated.
OK, take a DD 9500 seies, tune a 4-5 cu. ft. box to 30-35 hz, have awesome SQ out of it. and still hit around 148-149 db in a stock class sedan with everything in the trunk. The DD's are untouchable, take a good look at the Treo CSX, then my avitar, notice any similarities? How could you honestly give any props to a company that merely clones a product? as for audioque, the HD serious is merely a 9500 series DD without the free flow cooling, and with different spiders. this company was started by the late Alice Sandu's husband, yes she created DD. This is all a family business, and they do it very well.
Battery Suggestions?
trinitymatt replied to qtipextra's topic in Amplifiers / Head Units / Processors / Electrical
I would recommend an optima D31M, 1125 CA, that is what I run in my trunk, my cousen also whas one that ran his 150.2DB car for 2 days with no alternator. If you search on ebay you can find them for $190.00 shipped. optima D31M on ebay -
head unit installation problem
trinitymatt replied to Twitch's topic in Amplifiers / Head Units / Processors / Electrical
everyone thinks I am completely crazy, but I always run a dedicated 8 gauge, both constant 12V and Ground to our decks, I realize that this will not fix the other problems, but at least the deck will work. that's how all of our comp cars escept the Saturn are. -
no it is etched into the metal, but the power LED is blue, that add's a nice little touch. This is the new eclipse marine line. I just got it off of ebay for 145.50 shipped. Pretty bad that I have an amp that alot of people would love to have(Eclipse 3640) but I won't even be running it.
110 DB S/N .03% THD 65W X 4 @ 4 ohm 2 ohm stable concept HP65.4 pics coming soon..
I have an eclipse 3640 4 channel high amp. I was wondering if anyone knew of a link to a full spec sheet. I got a new high amp, and was hoping to have a full spec sheet for potenial buyers.
Can anyone recommend a H/U
thanx everybody. decent fix? ^ do you think that will do it? -
trinitymatt posted a topic in Amplifiers / Head Units / Processors / Electrical
I am currently running an alpine 7995, at this point it is the cleanest deck I have ever heard. Has anyone heard one of the new Panasonics with 106 db S/N and 5V preouts, or does anyone have any other decks they would recommend? -
Battery Recommendations
trinitymatt replied to ///M5's topic in Amplifiers / Head Units / Processors / Electrical
sorry free shipping -
my cousen got his for under $200 buy it now shipped there's one on ebay right now 189.95 + $3 shipping. optima d31M on ebay -
I just searched, found one that was an auction, not buy it now, and put my bid in for 175, I just did the same thing and picked up what I believe to be the cleanest high amp on earth for $150. At least I hope it is, I'm getting rid of one of the world famous Eclipse 3640's -
I have seen pics of that box with the insert, awesome job, what DD was that?
I agree nice choice of equipment, I bet your sub looks alot like my avatar, except mine is a B series.
denim I think I got my optima D31M for like 175 on ebay. -
That is basically what I'm planning on doing to my Grand Prix, cut out the rear deck, build a new reaer deck covered with grill cloth, one that will go in, and can be pulled out. Wall behing the seat, build the bottom, top W/sub hole and ports(if going ported) and sides of the box seal the back half to the front wall. slide it into the trunk, seal the back half, to the existing wall behind the seat. add another peice of mdf, cut to seal behind the box. Obviously this depth is limited to the depth of the rear deck. use spray foam insulation around the edges to make sure it is 100% sealed off. Drop your sub in through the rear deckinto the sub hole in the top of the box, put your grill clothed rear deck back in. then finish the trunk off however you want.
Small trunk, big box. inside, seat down. In the lane, I had bad pic timing, it metered on a 3055 at 148.3
I have an in dash epic 160, however I was only planing on useing it for the voltmeter, and the internal mic that is dead on with the 3055. That might work too, huh? -
L7 or X... decissions decissions...
trinitymatt replied to AcIdBuRn83355's topic in Subwoofers / Speakers
recone kits aren't out yet, give them a couple months. -
so I should put my Audiocontrol Matrix back in? -
our team has 3 7995s that is what our stock class cars running 1 15 are hitting upper 140's low 150's on. just incase we decide to run Iasca we added RCA 2 Ainet aux inputs. because at that volume Iasca will require us to run our stock class car's outside the vehicle. But we all want at least 160's needless to say the other 2 team members are leaving stock class because they want more amps. When you are running 8800Wats RMS to a single sub, you need as little distortion as possible right, we still haven't blown our 9500 series DD's -
we hit 148.3 in a saturn sedan with 1 15 + 1 2400 Watt amp. Doubled the amp but due to the cold weather at the comp only hit 148.8 with 1 2400 watt amp per coil. If you want pics of the install message me. with 1 amp it was a stock class sedan.
would it be better to build a large slot port, with the 3/4 in MDF behind the seat as 1 side, the modified 3/4 inch rear deck as the top(with the 12 and dual ports), make a back and sides out of MDF and build it in the trunk? That would still solve the problem of having to pressurize the trunk area too.
