sefugi
SSA Regular-
4,349 -
Days Won
12
Content Type
Profiles
Forums
Gallery
Everything posted by sefugi
The Bass-IC Collection: Stanley Clark
^^^THIS!!!! Now have a Bad Rabbits folder and so does my daughter.
With the power and space you have the DCON in a 10" or 12" would match up. They are said to be surprising for output for the money spent.
Very Nice!! Great work!! I've seen those tubes used as ports, but not as the enclosure itself.
Jump the side pin (#86) to top pin (#87) and pin (#87) is connected to chassis ground. HU ground can be connected to wires that are connected to pin (#87) I am not good at using programs for drawing so here is a quick diagram I scribbled out.
I would recommend not putting crossovers in the door or behind the door panel. You do not want the crossovers subjected to moisture.
Cannot say for sure, but when I got mine I beleive they said 19mm. From PDF- 19.0mm X‐Max by 70% BL method one‐way (38.0mm peak to peak)
From what I can tell the difference on what you had and what seems to work is you had caps and it liked small letters.
Did you get the relay figuired out?
Yes that would be fine for under the seat, but you can usually fit them under the dash or behind the kick panels, then the double wiring (tweet/mid) has a shorter distance to run. To me it helps keep it a little cleaner and managable.
Not if they give detailed measurements in the product description.
Wouldn't you need speakers before you make the rings?
Here is an easy picture for the basics and this will be done for each side (left and right) Hope this helps.
Here I mention hot glue for the dowels and don't even think about using it for the cloth... Thanks ^this and spray adhesive like used for attaching carpet to an enclosure ( is that CA glue) I got a bunch of foam and fabric spray adhesive for the vinyl, I'll try that too Between the 2 you should be ready to go!
If you are going more for SQ, using 1 sub leaves more $ for squeet amp.
Nice Suggestion on an amp for a show car!!
Agreed on the seat covering it, really looks nice, and those bars and fuses under that glass is gonna be sweet!!
I'm still pretty sure you have fine ride but I'm having a problem focusing--- on it.
Here is your pic! Sharp lookin' truck!
Need to get some components! figure ill just run the 100.4 bridged and be really cautious on the gains. Will be a PITA to match the gains though. I know i've read that this is easy, but as far as i can tell this is going to be a b**ch. I'd at least have to have an Ipod with an external speaker to have some tunes.
I'm all about crazy and out of control
300 for parts and labor sounds really good, I'd go that way also. Not havin' the tunes can be a bummer.
