heckvr4
Members-
240 -
Content Type
Profiles
Forums
Gallery
Everything posted by heckvr4
buy them and give us a review... i was looking @ buying them too.. but i went with crescendo :popcorn:
good luck bro ! go big ! even if it takes a while...
man you got all the mods looking at this , 6 User(s) are reading this topic 6 members, 0 guests, 0 anonymous users 1. heckvr4, 2. Shag, 3. patented17, 4. Sir-Lancelot, 5. lithium, 6. Julian
looks like a lot of work... very nice...
Electrical powering a sundown 2500d
heckvr4 replied to xxaderxx's topic in Amplifiers / Head Units / Processors / Electrical
Confusing, but it works haha. Alternator would be the best choice in the long run. Some Companies: DC Power, Mechman. I myself have been looking for a new alternator and came across the mechman site but have been unable to browse it because it seems to be infected with a nasty virus/spyware... x2 -
cool , thanks ill check it out,,, i want to gain maybe 15lbs,., should i get a weigth gainer? or just keep lifting and wait ..? hmm,,,
electrical for 2 saz3500d's?
heckvr4 replied to heckvr4's topic in Amplifiers / Head Units / Processors / Electrical
Yup . thanks, bassahaulic... -
heckvr4 posted a topic in Amplifiers / Head Units / Processors / Electrical
how big of an alternator's ? how many batteries , etc etc , would i need to run 2 Saz-3500d's 'safely' on my truck? they would be @ 1 ohm , just for daily.. -
I'm using jack3d right now, and it works for me. I get all the boosts with no ill side effects. The only thing I cannot do is run long distance with it. The protein I am using now is MaBSN Truess. Excellent taste and I have gained 10 pounds in the past month. I work out almost everyday for at least an hour. Looking to get stronger rather than put on a ton of weight, but this stuff works great. im almost out of protein, im going to give BSN true mass a try... were did u get it @?
great prices right too !
red panels are removable . Without them, the port area increases, port length decrease, chamber volume increases and the tuning goes up. It will cause 3dB more output from 41Hz to 50Hz or so. im hoping to start building the box next week... ill deff post pictures because im sure ill have a lot of more questions...
ok , i have 2 15'' fi btl's and i want to do a 4th order .... i cant remember where i read that btl's are not made or not good for 4th order designs .... its this true?? can somebody explain...
well i got an email from the guy thats designing me the box... The Fi BTL is not suitable for 4th order bandpasses (essentially a sealed box with an acoustic low pass filter). It will however work great in a 6th order bandpass(Essentially a ported box with a acoustic low pass filter). Magenta is a 6TH order bandpass, Cyan is a 4th order bandpass. As you can see the 6th order bandpass is better with the Fi BTL. Even if we make the 4th order bandpass into a SPL box, the SPL 6th order bandpass will be louder. makes sence to me... i just never heard of btl's not beign suitable for 4th order's... i keeep learning new stuff everyday
maybe a better box too,,,,
i ended up buying 'jack3d'... its working great for me! im 6'1'' 190lbs... lots of energy without the side effects , its only been 10 days but i like it so far... im just getting started in this buissnes..
15'' fi btl, sorry , its a lil dusty...
oops my bad
anyone have tryed ' jack3d ' ? its a pre-workout drink.....
if you have 2 dual ones just get one decent sized amp that runs at 1 ohm, wire up to 2 ohms then back down to 1 ohm. that easy, How do you wire 2 dual 2ohm to 2ohm and then back down to 1ohm ??? can you explain this to me ?
ok makes sence... lol so the GOTOGUY for 4th order designs is....???
is it safe to run my sundown audio 2000d at i believe .5 ohm? i have 2 15'' fi btl's dual 2ohm subs,,, so i can wire them to .5 ohm... i have a 05 f150 , 1 optima yellow top , 0 gauge , big 3 , xs battery 900d and of course the 2000d... am i ' safe ' ??? im currently savingmoneys for a HO alt.. please help...
Since you have lots of space to work with, wire your woofers to a "normal" impedance, and make your enclosure on the large side to increase efficiency. He already has the D2 woofers, so options are 2ohm and .5ohm. 2ohm will disappoint him I'm sure. I think you should build a large 4th order of Duran's design to utilize as much of the woofer as you can at .5ohm. Just keep a close eye on your voltage. Thank you sir ,very good advice. if i buy a second 2000d can i use one on each sub to run them at 1 ohm?? or how does it work? im deff getin the ho alt, and a couple more batteries. 4th order for sure ! If you get a second 2000 you can strap the amps together with the woofers wired at 2ohm. That will put each amp at 1ohm. ok cool... am i better of buying a second 2000d ?? orjust getting another bigger amp for both subs ??
