ssh
SSA Regular
    14,251
  • Days Won
    56
Everything posted by ssh
  1. ssh
    Help me pick my new sub stage
    If properly sealed from the trunk, your cabin volume would drop slightly, thus less room to pressurize, more cabin gain, more output I've always read from quite a few people that when they fired forward, they had a little better sq. Oh and your trunk shouldn't flex like a bitch, no nasty annoying ass trunk rattle
  2. If you have an air compressor then there's a whole slew of different sanders you can get, and they'll make life way easier. If not, you can look into the electrical orbital sanders, most are around 4"-5", they use either PSA pressure sensitive adhesive pads or a hook and loop setup. So whichever orbital sander you get, make sure you get the right pad types to match. I just bought a dewalt off amazon and they listed an assorted box of pads to go along with it, I just assumed they were the correct type. I ended up with a psa type sander and a box of hook and loop pads. Fortunately I was able to just spray the sander pad with 3m adhesive and stick the hook and loop pad (sanding disc) right on. Hope someone can learn from my mistakes
  3. ssh
    Hairtrick questions?
    lol. It's a new thing, trunk holes, specifically designed to mount circular shit in.
  4. I bought an orbital sander to help with the big open areas, it's helped cut down some sanding time, but for small stuff and curves it won't help much since the pads are like 4" 5" in diameter.
  5. Rossi is unbelievable man. If you aren't familiar with him read on wikipedia, search on youtube. Check out noriyuki haga too Video of Rossi duking it out with Stoner
  6. ssh
    Fusing on alternator
    Dc lists their output ratings when hot iirc
  7. ssh
    If there is no load drawing / requiring 300a then your alt wont ever produce 300a, regardless of rpm.
  8. Perhaps I should retitle the thread, for better or for worse.
  9. Sails / tweeter pods look good, im jealous cause my sails had no space for tweeters
  10. ssh
    As long as your fine with the wiring config, got enough volume for the enclosure and you can fit'm, I'd go with 3 of the xcons, hell you already got two
  11. ssh
    Wire quanity and size questions..
    NO! You are just supposed to KNOW! >:-[ Sigh, I guess I'll just do 2-3 runs lol. Sounds good
  12. ssh
    How are we suppose to know how many runs you have / need? Maybe list amps your using?
  13. ssh
    Your looking around 39" in width, what's the smallest width in the trunk area and opening to cabin
  14. ssh
    It could still help, just something to base off of. Any how, are you willing to fire forward and seal the cabin off from the trunk?
  15. ssh
    I know I always want more, so if you know that your going to want more and more then I would lessen the goal of sq and lean more towards spl. All of the drivers perform very well musically (yes I've heard all three drivers). I would try and find someone else who has a similar civic and competes, see what different enclosures they've tried and what worked the best.
  16. I'm basically going to post a link to some sort of web challenge, once the challenge has been beaten and or ran for a few days, another will be posted. Numero Uno http://lilgringos.com/hmm/1/ So far burko, shizzzon, and Sencheezy got it. Number Two http://lilgringos.com/hmm/2/ So far no one has gotten it. Number Three http://lilgringos.com/hmm/3/ Number Four http://lilgringos.com/hmm/4/
  17. You could try doing number three. People keep saying it's broken cause the page is blank
  18. ssh
    Okay I read in another thread where you were slamming projectors being used in a grand prix and calling it rice. And your buying this? This is rice. Any way on to actually being somewhat helpful... I'm guessing the zcons would be in a ported box? The xcons in a sealed enclosure would (personally) sound the best and get fairly loud, but the others in ported enclosures may be louder. Have you already used your 2 12" xcons in a setup before? Was it not enough output? Enclosure specs?
  19. I made it very very close in color so you couldn't do that, but I know screens vary so I thought id letcha have a shot
  20. Its a white picture on a white background. There's a slight color difference in the picture, so if you mess with the: contrast, brightness, level. You'll see some text. Then you gotta do somethig with the text.
  21. Then you got the picture, now maybe you should open it in photoshop and mess with the so i need photoshop if i took this route? Or any basic photo editor that can adjust... Hint: if your using a lcd screen you may not anything
