ssh
SSA Regular
    14,251
  • Days Won
    56
Everything posted by ssh
  1. ssh
    sub cutting out
    Is it only cutting out at high listening volume? Very well could be a ground issue.
  2. ssh
    sub cutting out
    What's his voltage dropping to at full tilt? How was the gain set, or is it simply maxed out?
  3. ssh
    Ssa subwoofers
    I'm doubtful, but I've been wrong before.
  4. Must be shooting some zombies from far away.
  5. ssh
    Best midbass for ft1-se?
    Fill them with rice, cat litter, etc, pour out, and measure.
  6. ssh
    Welcome to the IHoP
    Couldn't find the ball scene, but found another:
  7. ssh
    Welcome to the IHoP
    Remember in Jackass when the one guy dressed up as old man, and his balls were hanging out? Dog was going ape shit trying to get'm, and the owner was shocked and embarrassed.
  8. ssh
    Upgrade Questions
    Most people don't like to admit ever being wrong, so it's cool for the acknowledgement. I'm not sure how close to "rated" the Hifonics amps are, but unless you end up with an amp that makes twice as much power, your going to be hard pressed to hear any difference. If I were in your shoes, and I had the extra room, I'd get the third driver with the same coil config as others, build new enclosure for all three with a big port, and then possibly consider an amp change.
  9. ssh
    Welcome to the IHoP
    No one else click this, except Matt. You've been warned. That's what you need.
  10. ssh
    Welcome to the IHoP
    I liked both posts, but want to see it again. Third times the charm?
  11. ssh
    Welcome to the IHoP
    Skinny doesn't always mean good health, but I understand what you mean.
  12. ssh
    Welcome to the IHoP
    Shooting more, which would otherwise cost me more money, so I would be saving money.
  13. ssh
    Welcome to the IHoP
    Oh everyone complains about the stock on my rifle, they call it "tubber-ware," and they say dremeling out the front to free-float the barrel is a joke because it'll just keep flexing til it hits the barrel. With the rifle held up, I can slip a dollar bill between the barrel and stock, then it down on the bipods, and the dollar is stuck. So a stock upgrade is the next thing on the agenda. My original 3moa group was 15rds, then I took the caps off the glass to set them back to zero, and fired three on a new sheet to double check I didn't bump any of the settings. I've probably fired 70rds on the rifle so far. Luckily I can drive for ten minutes to go shoot, only hindrance is ammo cost, but I plan on reloading relatively soon.
  14. ssh
    Welcome to the IHoP
    Went to the range today and got sighted in. Started off with a 3moa group, and ended with a 1moa group of 3rounds. The bags I made helped a ton! I'd push the rear of the stock down into the bag so the crosshairs were above target, slightly squeeze on the bag, release, and the crosshairs would be dead on. Biggest issue for me is maintaining the same cheek-weld, and follow through.
  15. ssh
    Welcome to the IHoP
    Aren't you using liquid propane or something? High tax? My vehicle gets around 30mpg, so that's ~0.33 gallon for 10 miles, and at $3.35 per gallon, it would cost $1.10
  16. ssh
    Welcome to the IHoP
    I watched part of the second one earlier, but couldn't resist sleeping. The third doesn't have Megan Foxx does it?
  17. ssh
    Welcome to the IHoP
    Uh oh
  18. ssh
    Welcome to the IHoP
    For the tatt lovers:
  19. ssh
    Welcome to the IHoP
    Oh and aren't hippies the first to opt for plant matter before said meat?
  20. ssh
    Welcome to the IHoP
    Finished my work out in the late afternoon, and napped until an hour ago. I'm always shocked how quickly deads kick the shit out of you, guess our cns is sorta important.
  21. ssh
    Welcome to the IHoP
    I'll skim it later, but am dubious. Not saying there isn't some truth in it, but the conclusions are rough. Came from hippy central. Pretty much bet at the same college you'll find someone with the same arguments against meat. I'd buy into those quicker. Then feel free to find studies from other facilities.
  22. ssh
    Welcome to the IHoP
    Grains are cash crops, and I'm sure there's lots of money spent every year to make people think "whole grains" are healthy. American Heart Association doesn't have a great track record either, so it's not like I would pay too much attention to their healthy food pyramids. ^But those aren't reason enough to say it's bad.
  23. ssh
    Welcome to the IHoP
    Even if you disagree, you may find some of this interesting: http://www.direct-ms.org/pdf/EvolutionPaleolithic/Cereal%20Sword.pdf
  24. ssh
    Welcome to the IHoP
    Cereal grains aren't exactly healthy. Not if you have celiacs, but otherwise they are. Even so, I don't believe they are. They don't offer any nutrition that can't be found in vegetables and meat, and the grains have phytates which makes nutrient absorption lesser on humans. Lectin isn't great for our intestines, and can cause leptin resistance among other things.
  25. ssh
    Welcome to the IHoP
