Argent Audio
SSA Regular
    926
  • Days Won
    10
Everything posted by Argent Audio
  1. Argent Audio
    Estimate on ported enclosure fro 2 SA12's
    Use aero ports will be easiest for this box. A typical slot port will go outside of your max dimensions. 37 wide 18 deep 15 tall The ports will be firing out the side. Do you have enough room to one side of the box for proper venting? Andrew
  2. Argent Audio
    Vented box for 10"FI Q
    I will get a quote going tomorrow and post some results. Andrew
  3. Argent Audio
    Id like to stay within the dimensions I gave u, but if you need more space we can adjust the depth. I can go 18" possibly 19 depth. If it helps I don't mind aero ports either. Yo any word on the quote? This xmas bonus is burning a hole in my pocket lol Just got home from out of town so I will post a design tonight. Andrew
  4. Argent Audio
    Before I send you a request for money I want to get a solid design for you. So if you can give me your max dimensions that would be great. Andrew
  5. Argent Audio
    Your looking at $161.50 plus shipping. That enclosure includes flush mount. Andrew
  6. Argent Audio
    Were you looking for a box with a slot or flared port? Andrew
  7. Argent Audio
    Quote for 2 15' xcons ported.
    To keep things easy I'm thinking we try and fit some aero ports in there. Andrew
  8. Argent Audio
    The issue I am coming up with on this enclosure is that fact that you are physically limited on your width. With a width of 38 inches it will be physically hard to fit 2 15's and a port. Andrew
  9. Argent Audio
    Quote for 10" DCON
    If you can PM me your paypal email I will get a money request over. I only require a 25% deposit to get started. Andrew
  10. Argent Audio
    Quote for 10" DCON
    Double baffle just double the thickness of material where the sub screws down too. Andrew
  11. Argent Audio
    Quote for 10" DCON
    Your looking at $70 plus shipping for that enclosure. That includes carpet. Andrew
  12. Argent Audio
    Quote for 10" DCON
    I'm sorry, could you clarify on what you mean baffle inside the enclosure? Andrew
  13. Argent Audio
    Quote for 10" DCON
    Are those dimensions including the .75 inch indent on the sides? Andrew
  14. Argent Audio
    Quote for 2.25cuft DCON enclosure
    If you can PM me your paypal info I will send a money request over and start the build tomorrow. Andrew
  15. Argent Audio
    Custom Enclosure Order Status Thread!
    I'm replying to your email now Andrew
  16. Argent Audio
    The port area issue
    M5 is so very correct! This is what I use WinISD for modeling port velocity. I don't like the program for much else. Andrew
  17. Argent Audio
    2 Fi Audio SSD12
    Ok if you can PM me your paypal address I will get things moving. Andrew
  18. Argent Audio
    Quote for 15" Q
    Ok, I was able to fit 3.75 cubes with 57.75 sq inches of port. I used your max dimensions of: 18 tall 20 deep 34 wide I am indenting the sides 3/8th of an inch, if you would like no indent I can try and get closer to 4 cubes. This enclosure will cost: $148.75 plus shipping. This price includes the 15% off. Andrew
  19. Argent Audio
    With any box build we typically indent the sides so we can lay the carpet nice and easy. With this design I do not think it will be possible to easily carpet. If you want I can build the enclosure and you finish it anyway you like. Would that be ok for you? Andrew
  20. Argent Audio
    Quote for 10" DCON
    I can make what you created in Sketchup. Is this your final drawing of what you want so I can get an accurate quote? Andrew
  21. Argent Audio
    2 Fi Audio SSD12
    Ok with the dimensions of: 22 deep 15 tall 32 wide I can fit the min recommended by Fi. Your looking at $153.00, that is with the 15% off. Andrew
  22. Argent Audio
    Ported Box for 2 12" Kicker L7's
    Yes that will be fine. Andrew
  23. Argent Audio
    I will get a design going, can you give me your max dimensions? I think the ones that are most important are the height and width. I would like to keep it level with the rear seats and as wide as possible to give you trunk space if needed. Andrew
  24. Argent Audio
    Quote for 10" DCON
    Hello draco159, I will from now on contact you via here. I will sit down in a bit and make a quote for you. Andrew
  25. Argent Audio
    Ok so its back up!!! Kicker recommends a pretty big range so I picked something right in the middle at 1.75 cubes per sub giving you a total 3.5 total. So your looking at $233.75 plus shipping for a flared/kerfed port, double baffle and flush mount. And if you wanted just a regular slot port your looking at $170.00, this also includes double baffle and flush mount. All of my enclosures come with 45's in the corners. The only add on you can do is wooden dowel bracing which I do not think you will need because your box is not very large. Andrew
