The enD
SSA Regular
    3,835
  • Days Won
    20
Everything posted by The enD
  1. The enD
    Sundown e 12 is a hoss
    Reading OP's post I did not imagined he had the amplifier on another subwoofer and he simply reconnected the wires when he got the E12, without any adjustments to the settings. But after you mentioned it, that might have been the case, tho he pointed out he has done some settings. With my -1, I though you suggested a new subwoofer and box(basically ditch whatever he has now and invest even more $). My bad.
  2. The enD
    J-roadtatts DCON enclosure build!
    www.soundsolutionsaudio.com/forum/topic/39156-how-to-post-pictures-in-a-thread
  3. The enD
    Exactly. And you have it in the biggest suggested box, 2.0 cub feet. I have a SA-12 in a 1.75 and while barely moving it still makes some noticeable bass at low levels.
  4. The enD
    Welcome to the IHoP v.2
    Toyota Celica 6th gen
  5. The enD
    Clock works except when the key is at OFF. It still has power,only the lighting is not powered when off. It also switches off at crank, but the time delay is not visible. My bad, clock DOES shut off while cranking. Bypass the fuse box and wire directly to the battery? Not sure if that's a good idea though... It will still most likely happen. Starter uses a bunch of volts and HUs protect themselves. Good point. Sounds like a waste of time trying to bypass it anyway. For you, maybe yes. Bypass the fuse box and wire directly to the battery? Not sure if that's a good idea though... X2 I'm pretty sure it cuts off at start to protect some sort of Under or Over voltage problems. Maybe if you had another battery source or possibly wire it to a cap? I am not adding a cap, lol. I've recently added a battery in the back. My voltage is good. It even cranks differently, more "stable" so to speak. I'll have to measure the exact voltage at cranking.
  6. The enD
  7. The enD
    Yes that. Wiring it directly to +12 won't help as It will be more annoying turning it off every time I shut the car. Google is not helping too. I might buy a relay and wire it to the clock or whatever.
  8. The enD
    Turn the head unit off before you shut off the car, when you get back in it should stay off What good is that?
  9. The enD
    How do I make my head unit not shut off every time I start the car?
  10. The enD
    Insanely fast?
  11. The enD
    Worth the watch
  12. The enD
    How do you apply the sundown audio sticker?
    As the guy in the video.
  13. The enD
    Applied mine in a similar fashion.
  14. The enD
  15. The enD
    Suggest a loud 10" sub for a sealed box
    So you have a sa-10 in a ported and you don't like it ?
  16. The enD
    Can this method be used for setting the LPF? Yes, method is exactly the same except you would obviously want to have the LPF set at maximum instead of minimum when measuring the first voltage and then turn the knob down until you achieve the calculated target voltage. Will also say that the .707 only works properly if the filter is a butterworth. If it's LR then the multiplier would be different. Do you have idea what type of filter do the SAZ line from Sundown use? Me : Can I just use the method above with 707 ? In the example above it changes from 2.0v to 1.414v not 2.0 to 1.9 So who is right?
  17. The enD
    I am playing the sub at 2.5x rated power. I want to do it right, now quicker.
  18. The enD
    Everyone prefferences are different. I don't really have anything usefull to put on a second screen to care. Maybe if I was a game streamer.
  19. The enD
    My Settings> Notification Options, uncheck whatever you don't like. Been there, done that, several times. Block SSA email if you dont care?
  20. The enD
  21. The enD
  22. The enD
    http://www.homebuilthifi.com/project/3983 That seems like a nice box. Only 421 pounds.
  23. The enD
    Arm's lenght to a 22"
  24. The enD
    Might leave the PC for the night and wake up with a cracked password... and some other cracks if you know what I mean
  25. The enD
    Shit, I put some nude pics of this girl I know, in a .rar and now I cant open it cause I forgot the pass...
