Bearlokey13
Members-
111 -
Content Type
Profiles
Forums
Gallery
Everything posted by Bearlokey13
With what you have given us I'm going to say no. If you want real help give us more to work with.
That enclosure should work just fine, tuned for the lows.
just to be clear, i didn't buy the 18. I'm just planning ahead of time to see if it's worth it. Will 2 12s be as loud as one 18? Install dependent but you'll have almost the same amount of cone area.
2500w @ 2ohm
Bearlokey13 replied to Denven's topic in Amplifiers / Head Units / Processors / Electrical
check out soundstream rubicon amps .. good amps No. He needs an amp that puts out 2500 watts at 2 ohms not 1 ohm. -
IMO, you should just go with the NSv.2s because I would hate to see you buy the sa's and cook them and have to buy all new woofers.
If you will be running 6k watts daily then get the nightshades. The SA series woofers are very nice but the sa 12 is rated for 600wrms.
If you are chasing the lower notes tune somewhere around 33hz.
Don't worry about the bp option if your Q is the new model. It is for the 2009 and older models.
Try any of these guys. Or Argent Audio or the SSA store.
it jus said in the manual, Fully Chargered-12.8 Half Charged-12.5 And i dont have a volt meter to get the exact number, but im trying to get one That's with vehicle off. With vehicle on i'm sure it 14+ yea i assume its around 14 also, but i think just to be on the safe side and to get more power id like to get another amp, xs or kinetic? which is the best and cheapest? Those two words never go together. Especially in this hobby.
Yup, as far as I know SSA isn't set up to even make an 18" Icon basket so you're on your own.
My Power Bastards alt installed
Bearlokey13 replied to Cant Get Enough's topic in Amplifiers / Head Units / Processors / Electrical
Seriously dude? -
Again, if you're so concerned about weight that you can't add another battery in the back then you are looking at the wrong equipment. My biggest concern here is that you will drop around $1000 on a sub and an amp and fry it in a month or so cause you have your stock charging system. I've had that happen and it sucks. If you're looking at anything north of 1000 watts you should really consider at least another battery. IT TAKES POWER TO MAKE POWER!
You're looking at the wrong equipment if you're worried about weight. The BTL is somewhere around 70 pounds and an enclosure for it won't be a slouch either. If you don't want to add an extra battery fine, but at the very least pick up a volt meter. Edit: spelling.
Is Saz-2500D Overkill for a Kicker Solo X 12
Bearlokey13 replied to StlJohnny's topic in Subwoofers / Speakers
It'll be fine assuming you have the electrical to back it up and don't clip the hell out of it. -
They will work perfectly fine in a sealed enclosure, just make sure you stick within Fi's recommended size range.
AQ3500D to SAZ-4500D
Bearlokey13 replied to harveywong's topic in Amplifiers / Head Units / Processors / Electrical
Yes. -
For two BTLs I would say SAZ4500d but I believe those are out of stock. The SAZ3500d would push them just fine though.
No one with any experience is going to come on here and say that you will hit the numbers your looking for just by looking at your equipment list. You should know by now that it is all in the install and to hit 150+ out of a trunk takes WORK. Now, with that in mind, what exactly are you looking for?
Audiopipe AQX3500
Bearlokey13 replied to loondizie52's topic in Amplifiers / Head Units / Processors / Electrical
Crescendo Audio 3KWP That is probably the cheapest 3k+ watt amp that I would buy. Same build house (Zenon? Xenon?) as the SAZ3000d. -
Audiopipe AQX3500
Oh, you're right. my mistake. No experience with Audiopipe amps, sorry. -
Audiopipe AQX3500
You'll need a bigger battery bank than that to reliably run that amp at .5 ohm. You'll also probably void the warranty. You'd be better off spending about $30 more and getting to AQ2200D's and strapping them together, more reliable and you won't void the warranty on your amps. Edit: whoops, mixed up the AQX3500.1 and the AQ3500.1 -
Your Bl won't know the difference. The main reasons people choose Sundown are the unbeatable customer service and the very high quality of their products. Choose whichever amp you won't you won't hear a difference.
