Typicaljawaiian
Members
    118
Everything posted by Typicaljawaiian
  1. Typicaljawaiian
    Small port, decent TL score (AA SMD)
    What I got now is very musical (even at high volume)and I love it as a daily setup. I just crunched #'s on the torres box calc and I'm gonna go with 3.5^3 tuned to 41.5hz w/ 80 inch of port. Results on Saturday!
  2. Typicaljawaiian
    I've had other configurations w/ my BL 15 $ JL 1000/1 but not this set up no. I figure walled at the trunk would be best for comps. I know, I've had tons of people saying I should be close to 150 Yeah, just HO alt. No $ for batteries yet. Don't know the exact peak of the vehicle.
  3. Typicaljawaiian
    I'm not "pissed" but I am a LITTLE let down. I was hoping 145.0 with the gear I have now. Maybe this box and two solid batts will help
  4. Typicaljawaiian
    Oh yeah, it's a 6" inch aeroport. I wanted to try something different. The thing is it sounds REALLY musical. I can't do two 6" ports, I don't have the space. I have a comp on Saturday and plan on doing a SPL box. I'm thinking 3.65^3 @ 40hz w/ 72 inch of port? Should I tune lower? Also did my first two beassrace runs in my life (practice) and got perfect 129.9 on the second run w/ Bone - See You At the Crossroads!
  5. Typicaljawaiian
    Tuning box below manufacture's Fs
    I'm looking into buying a 15" BTL fully loaded. My question is, can I tune my box lower than the recommended fs frequency? If I did, would it affect the sub in a bad way? Poor sound quality? Just wondering if there would be a negative effect on the sub. I think the fs frequency on the 15" BTL is 37.9. I like low frequency hip hop and want to tune my box low like 30 hz (at the lowest 25 hz). Is this not a good idea, what would be the result?
  6. Is the DMM method a fairly accurate way to measure the watts output of an amplifier? I set the meter on AC volts, connect leads to speaker terminals (w/ subwoofer still hooked up), play a sinewave burp and take that reading to determine how many watts went to the sub. Does that sound correct? I already set the gains w/ an o-scope so I'm not trying to do that. I want to calculate how many watts actually is going to my sub thanks
  7. Hypothetically speaking If my sub is 1.5 at each coil, I wire down to .75 ohm. Now with the sub hooked up I burp 50 hz. I get a DMM reading of 40 volts AC. My voltmeter showed 14.2 for the duration of the burp. Say the imedance went up to 1.3 ohm, what would the equation be? Do I need to get a fancy clamp meter or something?
  8. Typicaljawaiian
    PSP port questions............help!
    I have a 15" AA SMD that's powered by a Stetsom 7k2e. I will gain down to 3500 - 4000 watts @ 1 ohm. Biggest enclosure I can fit in the trunk is 4.5 - 4.6^3 before displacement. The sub will take up .24 cubes and bracing .2 That leaves me w ~ 4.05^3 before port. I'll be using a 6" PSP Aeroport. A few questions I have are 1. Do you find port area in the straight length pipe, or at the very end (diameter of the mouth opening)? 2. My PSP has a 6" diameter straight pipe that flares out to 8" at the very end (on both sides). Which number do I use to find port area? 3. Do PSP's really require half the recommended port area as a slot or straight round port? If this is any help, these are some specs on the sub Recommended box size: 2-4^3 Xmax: 32mm one way Effective cone area: 810 cm
  9. Typicaljawaiian
    op questions 1 ? 2 ? 3 ?
  10. Typicaljawaiian
    Bump for more answers to my op questions
  11. Typicaljawaiian
    Thanks for the help So.......... My 6" aero opens up to 8" at the very end on both sides. That gives me a port area of 50.xx^2 Now I read somewhere that PSP Ports require less port area (not port displacement) than slot ports. Some say close to 50% less port area. That would mean I am close to your recommended 90 - 110 square in?
  12. Typicaljawaiian
    Cool, thanks! Back to my questions. 1. ? 2. ?
  13. Typicaljawaiian
    Right, my bad. ~32 - 33 hz
  14. Typicaljawaiian
    Ok, say I were to do a slot port, how much port area would I need for this application?
  15. Typicaljawaiian
    High Output Alternator Toyota camry 97
    I'm pretty sure DC Power makes that
  16. Most of the time people are like "give as much info as you can". Man, that was a lot of info!
  17. Typicaljawaiian
    BTL problems continue
    Equalizer, right?
  18. Typicaljawaiian
    Fi BTL 22? IB22?
    90 grand up front and we'll start talking $90,000!!!!! Is that per sub!?!?
  19. 09 Toyota Yaris Sedan FTW Big 3 I paid $16,000 brand new! 40 mgp easy!!!
  20. Typicaljawaiian
    AA SMD or DC lvl5 15"
    After all specs and pricing is weighed, what would be the better route? Amp would be a stetsom 4k2d or saz 3500d. Biggest enclosure I could do is 4.2 cubes before displacements. I will use two 4" x 17" aeroports (double flare). Thanks
  21. Typicaljawaiian
    Thanks 4 the replys fellas. Specs for the SMD say anywhere from 2-4 cubes will work. I figure w/ enough power, I should be alright in a 3.5 cube enclosure (after displacements)?
  22. Typicaljawaiian
    wouldn't happen to know the DC lvl5 recommended specs for ported enclosure? Anyone know the displacements of the two different subs?
  23. Typicaljawaiian
    Yeah, I plan on getting in the lanes from time to time. This would be my daily though. If I can't afford the SMD because I still have wire, terminals, batteries, MDF, etc. that I need to buy, what would be next in line?
  24. Does anyone have any reviews or info? Im thinking of trading my JL 1000/1 for a 1400d.
  25. Typicaljawaiian
    Crossfire 1400d
    S**t man, I almost did it. Thanks form talking some sense into me!
