exxd
Members
    54
Everything posted by exxd
  1. exxd
    18" BL Box Volume question...
    thank you for clarifying that for me, i think i will try it out first and see if i like it. :) i was just thinking that it might hurt the woofer for some reason.
  2. exxd
    EDIT: Well i think i have a solution to this dilemma, since the box is already put together and rock solid... im thinking i can shorten the entire length from 47 to 40, which brings the volume down to 7.5 cubes and makes me happier .... just gotta butcher the box
  3. exxd
    thanks for your reply. the problem is that here on the forums in the fi technical>bl box enclosure thread it states BL 18 – Ported box we recommend using 5-10 cubic feet @ 30-37Hz tuning, you can tune a little higher if you wish but we recommend keeping it close to 32hz for a daily driver. Again the same 12-16 square inches of volume applies per cubic foot of volume. ---------------- So that is the information i used when i was designing the box. And that is also the box that i ended up building . Later while on the website looking at the products again, i noticed it mentioned 5-8 cubes. so now im confused and starting to get slightly saddened that i build the humongous box that may not even be good for my sub.... PS. How much bracing do you think i can add to take up space? and what type of material?
  4. exxd
    Amplifier/Sub Ohm question
    someone told me having 1 fi 18" bl in a box with (9,3 cubes) will really slap some lows. but i was wondering will it only be good for lows or will it be good for the range of the speaker including the lows?
  5. I have an old kicker 1200.1 amplifier but I'm not sure what Ohm stability it has and I'm wanting to buy an Fi BL 18" dual 1 ohm. My question is what could happen if I wired the dual 1 ohm woofer up to my amp and my amp isnt 1 ohm stable? And how can I find out if my amp is?
  6. exxd
    ok thanks man!
  7. exxd
    ok guys, d2 18" bl ordered and i just finished building the box. my phone is messing up atm so im unable to upload the pics of the finished box minus woofer. but here is the exact specs of what i built. i have a question as this is the first time ive built a slot ported box.... where would be the best place to cut the hole for my woofer? right in the center of the face place? or closer to the opposite end of the port?
  8. exxd
    First you can't wire a dual 1 ohm sub to a 1 ohm load. A d1 can only be wired to see a .5 ohm or 2ohms. Also if the amp is the KX series than yes the amp can handle the 1ohm load, but the sub would have to be a d2. yes it is a kx 1200.1 and thank for clarifying the d1 d2 situation will be ordering my 18" d2 to be wired down 2 ohn
