j-roadtatts
SSA Supporter L2
    9,752
  • Days Won
    197
Everything posted by j-roadtatts
  1. j-roadtatts
    Welcome to the IHoP v.2
    Not quite finished. But figured I post up some pics. Still debating on doing some pin-striping.
  2. j-roadtatts
    I’ll give you Dutch. A Dutch oven that is!
  3. j-roadtatts
    Nice stash!
  4. j-roadtatts
    If anybody needs isopropyl alcohol. Check the grow stores!
  5. j-roadtatts
    50 should be plenty. If I had to guess I’d bet you’ll only need somewhere between 30 and 40. I’ve only had issues with the pump overheating the water in 20 gallons or less. I’ve never ran a continuous flow system but use a pump on its side with an air hose attached to it in Lou of air stones. I personally am not a big fan of air stones. As is a breeding ground for bacteria. Depending on the air pump type, it could possibly discharge oil into the reservoir upon failure. Plus I always just hated the sound of them humming. is your RO system for your whole house? or just an under cabinet type?
  6. j-roadtatts
    Temperature sensor possibly touching the wall? Is there a calibration dial somewhere?
  7. j-roadtatts
    I agree is the simplest. Also appears the most popular for vegetables too. Especially in Europe and at least commercially here. should require less reservoir volume I’d think. Being as the water level stays low in the field. The pump running continuously may heat the water up quicker in a small res though, so could be moot. May want to have a spare pump handy is about my only other thought. Not that they go out often, but is so vital in that setup. Are you planning on staying with the jars until the roots drop? Or do you have another plan for propagating the roots?
  8. j-roadtatts
    I’d think a larger drain would be quieter. I’ve had a setup on the other side of a wall I slept against. With a 2” drain and about 4” of fall was pretty quiet. I’m definitely excited to see how it goes for you. Would love to see more pics once everything is going or if you change anything!
  9. j-roadtatts
    2015 Hyundai Sonata Sport/Limited
    That tint came in tight! Super clean work brotha!! Thanks for posting so many pics.
  10. j-roadtatts
    Nice turd!! My mustang needs a tail housing gasket. Hopefully isn’t warped. Car can eat some parts. Wish I had the cake for a crate/trans combo.
  11. j-roadtatts
    Right! A new pair for the truck was only $60.
  12. j-roadtatts
    Super cool manifold btw! I was really curious how you were using the 1/2” pvc. the moisture sensor sounds like it could possibly be cheap insurance. The only time I had one in the house and on the second floor. I had a third tray that the reservoir and main tray sat in. So if there was a failure.
  13. j-roadtatts
    You have me wanting to build something now. Just have think of a place that passes the WAF. Haha After seeing what you have and going after an ebb and flow that fills periodically for a short time and then drains. Here’s the first suggest I have to propose. you could do a tray that fits under that top. You could make the top interchangeable to fit different pots and configurations. Then use an ebb and flow drain kit or emulate it. That gives you an adjustable overflow drain height to control the water level as needed. The pump inlet is the main drain when shut off. And the overflow creates a waterfall during watering. Now the bonus idea. You could do 2 smaller trays side by side. Would require two pumps and drain kits. But you could run them at separate times so could get away with a lot smaller reservoir. Also would allow each side to be set to different water levels if desired. Could run just one side if you aren’t using the other half. Could make the interchangeable tops in a halves as well. would be easier to find two small trays to fit in the size you have anyways. I would suggest either commercial restaurant tubs or concrete mixer tubs. Both being super cheap and the restaurant one probably being food grade. I personally would start with watering 20 minutes every 3 hours. The digital timers available have 8 stations so works out perfect.
  14. j-roadtatts
    You are doing something right if the roots are blowing up like that! are you starting the seeds in rock wool? What do you think the ideal neti pot size Is now that you have worked with them?
  15. j-roadtatts
    I could probably get into the 6” pvc idea. I’d shoot for a kinda industrial steampunk look with an Art Deco flare. As long as it has a directioin I think it will be aesthetically pleasing and a great conversation piece.
  16. j-roadtatts
    I think you lost me. Like a moisture sensor on the floor? how are you controlling the water level in the field if it is flood and drain. As in what shuts the pump off when it is full? Are you using an automated drain to put the water back into the reservoir when the watering cycle is over? I would think that should be about the only electronics other than a couple timers and a pump. As far as the water side goes.
  17. j-roadtatts
    he is probably trying to regulate how much food they intake with that many. Otherwise all depends on the size of the feeder and the amount chickens. I have five currently. The chicken feeder holds about a half a 40 pound bag. Could easily build it bigger feeder and waterer if needed. I also have a large amount of wild birds that come feed as well. Probably all the ones that were used to my bird loving neighbors feeding them every day. About the only thing I left off that list is will need a water heater in the winter. With five chickens I get about nine eggs every two days. Can’t eat them quick enough.
  18. j-roadtatts
    I’ve been composting the wet leaves and stems so we will see LOL
  19. j-roadtatts
    Is the exact system I would build if I did an Aeroponic. Ironically have enough parts laying around to probably build about six different systems. Just no space. Lol
  20. j-roadtatts
    Why would you need a moisture sensor? What would you use it to control?
  21. j-roadtatts
    I haven’t asked if you plan on doing any overhead drip system? Assuming you’re not and just rely on the wicking. The flood and drain will require a reservoir large enough to fill and then some as we discussed. The NFT constant flow on the other hand does not. The reservoir could be substantially smaller as the pump can only circulate so much water at once. as far as the plants are concerned they will not know the difference. i’m not familiar with each particular crop. But some do not care for wet feet. That would be the only reason to stay away from the constant flow. which I doubt is a concern with any you are growing.
  22. j-roadtatts
    I know I sent you pictures when I built it four years ago. Don’t know if you remember, the main structure is built it out of an old playhouse. The type that can usually be hard for free, if one is willing to go pick them up. Easily a gheester of cedar and Coated 4x posts.
  23. j-roadtatts
    Pretty low maintenance. I clean the coop twice a year. Change the hay in the egg boxes a little more often. One bail of hay has lasted four years. Feed and water them about every 2 to 3 weeks. I feed them mealworms in the winter, and let them scour for bugs in the summer. They eat a little more food in the winter. you’ll know when they need either as is about the only time they will follow you around instead of running away.
  24. j-roadtatts
    Here's pics as promised. Can see a bin I stared for my for my compost pile with scrap plywood. Also can see chickens fuck up a lawn. But they are great mulchers.
  25. j-roadtatts
    I feel dumb. When I estimated, I went long hand. And when I went for the circumference I did a 4” radius. Doh Found a sweet calculator that does displacement of liquid in a horizontal cylinder based on depth. https://www.mathopenref.com/cylindervolpartial.html Twenty feet of 6” Filled 4” deep is only 21 gallons. That should be easy peezy. How big is your fish tank?
