j-roadtatts
SSA Supporter L2
    9,752
  • Days Won
    197
Everything posted by j-roadtatts
  1. j-roadtatts
    Welcome to the IHoP v.2
    I busted out tenderloin filets and king crab tonight. Let the filets get to room temp. Then broke out the cast iron and baked them for about ten. Stovetop for 2 each side. Rested covered for about 5. Came out perfect right at 140. About a 1/16 of crust, and another 1/16 of brown. Then nothing but tasty pink.
  2. j-roadtatts
    Starting with hickory and maple and going to finish with just the maple.
  3. j-roadtatts
    Pork shoulder is in the smoker!!
  4. j-roadtatts
    People love a bubbly personality.
  5. j-roadtatts
    Is great free promotion. I’m sure that really appeals to the youngsters. Go’s with the “I hear and I forget, I see and I remember” mantra.
  6. A quick Google search of “dodge dart stereo shutting off“ revealed several people have this issue starting at around 10,000 miles. I would suggest reading those articles and seeing how they remedied the problem. please report back if you find something.
  7. I do not trust aftermarket plugs or but connecters. Maybe for the speaker signals but not the power. Please post a picture of the wiring behind the stereo and state which vehicle this is in.
  8. I personally bypass all plugs other than the actual one on the back of the radio. I soilder and heat shrink any other connections that need made. I definitely discourage the use of any crimp connectors. If you are using an aftermarket plug to attach to another plug before the plug on the stereo, I would run a couple zip ties around that aftermarket plug, if you are not willing to bypass it. Are you stating that you have the constant battery power and power wire connected together? Not sure why you would have two power wires hooked to one wire on the stereo? Should only need one to the red wire that is a keyed on power source, and a second wire to the yellow which is a constant battery source. The only other thing I could see being with the actual head unit is a glitch in the software. Which pioneers are known for. Would not see hitting a bump triggering an issue in that unless something is causing a surge. Perhaps a surge caused by those two power wires having slightly different voltage. If you feel like it is a glitch in the software it is suggested to reset the head unit three or four times. Perhaps pull the stereo out and wiggle all the wiring aggressively and see if you can emulate the problem.
  9. j-roadtatts
    Gainesville was beautiful. As was the college as well. She was just not feeling it. If I had to guess, Ole miss will probably be the pick if it’s one that direction. Or Georgia for their double dawg program. Which is structured to allow completion of eight years of education in six.
  10. I personally start with the super simple stuff first. If there is a issue with the wire from the fuse box to where you are hooking to it, bypassing it will reveal that. The next thing I would suspect is the plug on the back of the radio is getting pressed against something once pushed into the dash. What vehicle is this in?
  11. j-roadtatts
    That would be neat. I enjoyed all the video and pics I’ve seen so far!
  12. Perhaps run a temporary power wire and see if it solves the problem.
  13. j-roadtatts
    Looks like so far so good for me. Daughters graduation is about two weeks earlier!
  14. j-roadtatts
    If you are on FB Ryan you should follow a group called hot rods and Hotties. You won’t be disappointed.
  15. j-roadtatts
    Jared likey voluptuous!
  16. j-roadtatts
    The Fox body at about 3:30 looks insane. A subwoofer as a foot rest under the desk helps for effect!!
  17. j-roadtatts
    Always loved the first gen Camaros!
  18. j-roadtatts
    Super noob. Add subs without changing headunit?
    It is a user controled device that lets you fine-tune what frequencies/signals are going to each speaker. Usually controlled from a handheld controller or a laptop/tablet. You would feed a single imput signal of 20-20khz from your head unit into it and the device would allow you to break the signal up from there. It is not absolutely necessary, as there are usually crossovers on the amp that will let you narrow the signal down. It is nice though to be able to control everything on the fly from the listening position/driver seat. They also have a more elaborate EQ to work with. Most nowadays will let you EQ each speaker individually.
  19. j-roadtatts
    Are you interested in running a DSP? If so there is a slew of options.
  20. j-roadtatts
    June 8th and 9th in Indianapolis, Indiana.
  21. j-roadtatts
    Annikya got excepted to CU this week. Has been excepted to four other mid level colleges also. The one she is waiting on and that I think she prefers is Washington state. It is a good sign that CU excepted her, as it is on about the same tier.
  22. j-roadtatts
    That’s the plan!!! The only thing that could possibly get in the way is my daughters graduation. Need to check the dates and see how they correspond. I have a friend up in Fort Wayne I hope to visit also.
  23. j-roadtatts
    I feel you. The few times my parents did go on vacation they did not take the children. On the other hand I had hitch hiked over half the country by the age of 20.
  24. j-roadtatts
    They finally posted the dates for SlamOlogy. Hope to make it out there hell or highwater this year.
  25. j-roadtatts
    I’m flying to Dallas in about two weeks. Will be Anni’s last cheer competition before she graduates.
