j-roadtatts
SSA Supporter L2
    9,752
  • Days Won
    197
Everything posted by j-roadtatts
  1. j-roadtatts
    Welcome to the IHoP v.2
    Would probably not work with your smaller size. Although the idea is good.
  2. j-roadtatts
    The 70D body is looking like a good candidate. Almost as stellar as the 7D in the AF department. Plus better for video.
  3. j-roadtatts
    I need to text ya for a few prices on a ergo base. Would like to pay cash but if the deal is good enough I can break out the CC.
  4. j-roadtatts
    Shave my balls and call me Sally
  5. j-roadtatts
    Is it Friday now?
  6. j-roadtatts
    Wahoo!!
  7. j-roadtatts
    Have a great time brother!! http://youtu.be/O2_lU3adj5k
  8. That will work brother. I have done that before on a few other ppls rides. That looks about how everyone I found on google was done also. Not much room under that hood. lol
  9. A pic would help. From your description I would think you would want to remove the fuse block thats built into the factory terminal and install inline fuses. That would give you extra length and you can use your new terminals to clean up the install.
  10. Can you not just install the 35 180%. Will put the posts on the correct sides. May need longer cables, but if your reworking the wiring anyways shouldn't be a problem. If ya look at the pic I posted of my setup you will see thats the way it worked out.
  11. Ideally battery's from the same manufacturer will play nicest with each other due to being closest in design. Then again I may just be overly anal.
  12. Your right, the Diehard is an AGM. MY bad. Is ideal to have matching tech for optimum results.
  13. They are both lead acid batteries so you are good there. With a 220amp alt you should be good on power.
  14. You purchased a second battery for the rear yesterday and are going to leave the front one where it is. What was the question again?
  15. j-roadtatts
    Sent the wife to the Ivy's V-ball game today with the rebel. She used the 75-300 lens. Was a good starting point at least.
  16. j-roadtatts
    Chop's 85' S10 (single cab) * 3 18"s (4th order)
    Good to see your recycling Chop. Most would of hauled that bitch to the crusher. Keep the pics coming brother.
  17. j-roadtatts
    Let me guess. The bed is for the guys vacation home.
  18. j-roadtatts
    I have used this one quite a few times. Usually find it at the parts store. http://shop.advanceautoparts.com/p/bussmann-in-line-fuse-holder-for-atc-fuses-bp-hhg-rp/5171350-P?searchTerm=inline+fuse An even better watertight one. http://shop.advanceautoparts.com/p/bussmann-in-line-fuse-holder-for-atm-fuses-bp-hhu/25984858-P?searchTerm=inline+fuse
  19. Yes cut the ends off and use the smaller holes.
  20. j-roadtatts
    I assume your refering to this guy. http://www.amazon.com/Canon-200mm-2-8L-Telephoto-Cameras/dp/B000053HBB Whats the major perks to the 7D body? Compared to the Rebel? I will let the W try the Rebel and go from there i guess. Will be used for mostly indoor sports and dance recitals.
  21. j-roadtatts
    New build fi bl 15
    Should be* fucking auto correct.
  22. j-roadtatts
    Have pissed blood a few times also.
  23. j-roadtatts
    That sucks brother. Have been through the same thing a few times. They never did find a cause and it passed after a few weeks each time. Lots of cranberry juice was about all i had to work with.
  24. j-roadtatts
    That body is a Canon rebel xs 1000d. The larger glass is a 75-300. The shorty is more for macro I believe.
