forsellb
Members
    213
Everything posted by forsellb
  1. forsellb
    Your best record?
    You're a big guy impressive running times! U.S. Army lol Gotta be... And thanks, running distance is the best way to lose weight especially after I gained a few pounds a couple months ago. I got up to 252, then I had a knee and hand injury so the Push ups will be going up here shortly, hand is all healed!
  2. forsellb
    Your best record?
    Oh, and I weigh in currently at a whopping 236lbs, 6'3", and I can do all these times and numbers today.
  3. forsellb
    Your best record?
    Pushups: 50 Sit-ups: 69 Pullups: 6 Chinups:N/a Best time in 1 mile 1/4 mile 1/8 mile 2mi : 15:12 3mi: 22:40 7mi: 57:12 (I run 2mi+) Most weight in Benchpress: n/a Curls(single hand and double hand) n/a Leg press n/a Squats n/a Military press(most probably don't do) n/a
  4. X2 you could even have a lumber yard make the cuts for you if you really needed to. Just be patient and put a good effort into it and it will turn out fine Very true, I should look into that but there really isnt much out this way... I will go check though, finally got enough money to put it all together, been 'designing' it for a year now!
  5. I need a box for two AA Mayhem 12s, and Ive got the external dimensions, trunk dimensions, port lengths and everything. I just need someone to build it because I am in the Army Active duty living in the barracks and I cannot build a box, I need to order one. Please post if you know if a website, or if you know of someone that can build me one. Greatly appreciated guys!
  6. I was using a hand saw, sand paper, and 3/4" MDF. Ive never built a box or really anything close to it before...
  7. I feel stupid, I just found the section where I needed to go the first time. Thanks again!
  8. Thank you! I sent him a message asking basically the same thing here. I really want to find someone to build a box for me, I would if I could but I tried and failed miserably.
  9. I just want to hand my numbers off to someone, and have them build it. No one has any ideas?
  10. forsellb
    1Ohm or 2Ohm load?
    Thanks!
  11. forsellb
    1Ohm or 2Ohm load?
    If I have D1 12" AA Mayhems and I hook them up to the sundown 4500D by running the voice coils on each sub in series(which makes each sub a 2ohm load) then run them parallel to the 4500D would that give me a ~1ohm load to the amp? Or am I missing something here? Ive been told by many different people who are very well versed in audio that I need D2 and D1 for that amp. Any insight or help? Also the electrical is big 3, 220A alt, 3/0ga run to two 3100D batts, then hooked up to the 4500D.
  12. forsellb
    1Ohm or 2Ohm load?
    Alright, and wire them up exactly how I described it above?
  13. It would clean it up and it MIGHT allow more current, just a wee bit, to flow more easily.. I would suggest 1/0 just because it rocks
  14. forsellb
    SAX-125.2
    Wait your planning on buying the 1500D for a 1000wrms sub? I dont think I would do that... just me though Maybe go with the 1000D or 1200D.
  15. forsellb
    Fi lanyard.
    Those sound pretty sweet, I want a few myself.. Give some to friends and what not.
  16. Son of a B***h lol thats what I meant.. Im on here late at night most of the time and I make mistakes but yea Im going to be having a 1 ohm load for sure.
  17. Ok Im going to have a 220A alternator, two D3100 powermasters batts for the amp, and Im getting 2 AA Mayhem 12s D2 voice coils. Would I be better with the 4500D or 3500D on a 12V system? And is there such thing as wire gauge overkill? Say I run a 3/0 run from my alt to my trunk and its about a 20' stretch. Would it be fine using the 3/0? And when I wire the subs I want to use 4ga wire because the amount of power and I want to be 100% sure the wire is letting as much current through as possible. So would using an excessive AWG of wire cause any 'damage' or reduction in power, or would it not matter?
  18. Just pick whatever amp out of the two that you can afford and make sure you have the electrical to back it up. Alright thanks
  19. alright, then what about which amp would suit me better and would I be better with 2/0 or 3/0 run from the alt?
  20. It would be hard running 4 gauge wire to 8 gauge push terminals on the sub. True.. but where theres a will theres a way.. I kinda feel like 8ga would choke the current, but Im not a pro..
  21. forsellb
    Before posting ANY questions
    what about the definitions of words like linear, non-linear, ring and the lack of ring, and other words in that paragraph lol
  22. forsellb
    How about no, because then you would lose valuable information. Just suck it up and read it. I learned A LOT.. Im gonna read it a few more times just to make sure I understood and got all I could outta this!
  23. forsellb
    Hmm plexi/lexan box?
    Would it be possible to make a box out of the clear material and have it sound just as good as MDF if not better? I think Id like to go that route, why I dont know but a clear box would look cool to me.
  24. forsellb
    I know I have a car audio addiction when......
    What about you know you have a car audio addiction when your subs can knock Chuck Norris flat on his ass? Everything else has pretty much been said so theres nothing else I can really use...
