ulrisa
Members-
515 -
Days Won
1
Content Type
Profiles
Forums
Gallery
Everything posted by ulrisa
I think we need a video! lol I really like this came out!! Nice man!
OMG! You just made my day! I can't wait to pick up my 3500D!!
How many Ft of 1/0 for Big 3?
ulrisa replied to slim142's topic in Amplifiers / Head Units / Processors / Electrical
Actually the KMLX is the copper clad aluminum wire. It's fine as long as you aren't running over 200 amps I believe. But if you are doing the big three, it's better to just get the Fleks so that if you upgrade you already have the better wire installed. Fleks is pure OFC, so it can handle higher currents. -
I am kind of in the same boat as you. So far, for my car at least (2000 Volvo S40), only Ohio Generator and Irragi carry alternators that fit my car. Have you contacted them yet? They seem to have quite an expansive collection of alternators. I am yet to call DC power, but they are worth a try as well.
My Zune HD has excellent sq in my car. As far as I know, Cowon is known for sq. It won't be bad, but get some type of docking station. My Zune sucked to control while driving until I got one.
Wow! That is awesome, this is something I want to do in the future.
Potentiometer, a variable resistor.
budget:600 dollar laptop
ulrisa replied to lithium's topic in Computers / Electronics / Music / Games
You should check out the Dell outlet. Sometimes you can get great deals. I got the perfect laptop for me for $500 shipped two months ago. It was awesome. -
Is this something you will always be offering? I might pick some up in the future if you still are. Thanks.
Bracing helps, but with heavy subs (especially with a lot of motor force) really need a double baffle to support the weight and reduce flexing of the front baffle. The subs are mounted to the baffle so if you think about the force behind a powerful subwoofer pushing and pulling the baffle it might make more sense. Obviously you can get away with a single baffle with many subs, but with the stronger ones I see it as a requirement. I'm assuming your talking about the Xcon from your other threads, and I would definitely do a double baffle for that sub. Also, I don't really think flush mounting, or "recessing" the sub counts as a double baffle, you would have three pieces in that case. Hope this isn't confusing and makes sense lol.
Wow man, that sucks. It sounds like you have the same luck as me lol. My luck is so bad that my friends find it funny to make up hypothetical situations in which everything goes wrong for me, because it usually does lol. Just try to stay positive, at some point you'll get everything the way you want it. That's how I've been looking at things.
I'll get some pics up tomorrow
Nice! I really like the way this is turning out. Great job!
Kinetik 600 power cell
ulrisa replied to BanginGMC's topic in Amplifiers / Head Units / Processors / Electrical
Yes thats correct, but if you don't have enough wire for the negitive run then dont bother and just ground it...plus you need two inline fuses, one located near the starter battery and one located near the HC600 Inline fuse connected to the positive wire, correct? Yes, one near the front battery, and one near the HC600. -
Just wanted to say I'm excited to see how this turns out If it goes well maybe I'll get one some time.
Hifonics brutus BRZ 1200.1 or Sundown SAZ 1000.1
ulrisa replied to ExplicitYourSelf's topic in Amplifiers / Head Units / Processors / Electrical
Sundown FTW! -
Amp help please!
ulrisa replied to PhishHead's topic in Amplifiers / Head Units / Processors / Electrical
Do you have any other amps you could test it with? It would really narrow it down if it worked with a different amp but same wires and sub. If not, you could hook up a different speaker to the amp and see if it still happens, though I kind of doubt its the speaker that would be causing this (unless it is the wiring, which you are checking/already checked). It's too bad you don't have a circuit breaker, must suck having to keep replacing the fuses . -
The recommended specs are here Incriminator Audio: No Chrome, No Carbon Fiber, No BS! Period
Well I looked it up but I couldn't really find any information. I did see that the sd card adapter was limited to 4 gb, which might mean that 4 gb is the limitation of the usb port. One possible solution (kind of) would to get multiple flash drives/sd cards. Hope this helps.
It's possible that the interface is limited to 2 or 3 gb. That would explain why your 4 gb and hard drive wouldn't work, but your 2 gb would. Check the file system of the 2 gb flash drive and see if it is different than the 4 gb or the hard drive. Also, list your head unit and maybe I can look it up for you.
ok thanks so my next question is how do i partion it i new to this or get it to fat32 like my 4g flash drive my whole goal is to make the portable hd do what the flash drive is doing and addind more songs and movies. Thanks In Windows, right click the drive (make sure it's the right one!) and select format. You should be able to select FAT 32 under file system. This will erase all of the data on the drive so if there is anything you want on it, make sure to copy the files from the portable hard drive before you format it.
Found this again today. This is one of the vids that got me excited when I was waitin for my Leathals to arrive. Nice setup bro. That shit is slammin for 1 12! Thanks! Pretty soon I'm going to get another vid up because it's slamming even harder now after I changed the placement of the enclosure. I'll let you know when I do.
That is pretty much what happened to me. At first I had set my gains by ear, and I did get that smell. I backed down the gains for a while. After the sub broke in, I had done a few different things in my car and I figured I would reset the gain. It's much louder now and I do not get that smell anymore. Hope it is the same for you.
Seems a little strange to me. Are you sure you weren't sending a clipped signal? I think you should double check your gains and set them with a dmm or o-scope when you get the recones. Whoops, sorry I now see that you already know how to do this and I must have forgot to hit refresh before I replied...
You are really giving it that much? I have my amp set to 600rms and it is beating the hell out of me and my car. Hard to believe you are giving it that much power. Well I really like to have it loud lol. My car is built pretty solid for the most part, and I deadened the trunk a few weeks ago. The only part that worries me (for my future setup) is that my sunroof and roof flex pretty bad, but it's cool at the same time haha. It's good to hear that you are enjoying it though.
