Lord Baccus
SSA Regular
    1,343
Everything posted by Lord Baccus
  1. Lord Baccus
    My van and new toys!
    makes me wish i had money. can i ask what is the ballpark figure on a setup like that ? did you winn the Lottery
  2. Lord Baccus
    All Shall Fear Me now...
    its cool :0 i was just wanting to try something different Stiffer cone / less motor / more power sence im only working with 3000watts i figure the best way to make use of the power i have is go with a sub that requires less power to get up & going. problem with that is all the off the shelf subs are either cone/motor heavy ( need too mush power ), or just the oppisite lite cone /motor ( wont take much power ) so i spoke with John @ Pap and discussed using the stiffer cone from the new MOAB on the frame for the WMD w/ the new Motor its good for 1000rms per sub so i figure with a 3000watt amp ill be overdriving em for Burps about 500watts ea. in the same box that did 151db with the power hungry subs, hoping my plan holds water, shooting for a 154db realisticly 153 ish db
  3. Lord Baccus
    honeycomb polymer w/ Kavlar coated cone, 1000watt RMS, 21Lb Motor for 07' T/S parameters: REVC: 4 ohms FS: 34hz QES: .97 QMS: 7.2 QTS: .86 VAS: 3.6 BL: 14 MMS: 241g Sens:91db@2.83v
  4. Lord Baccus
    it can be done Pap has an 18" MOAB with that cone for 07'
  5. Lord Baccus
    sundowns 1500 vs kicker 1500
    is there a Kicker amp that does 4k ??? im lost !!! are we still compairing Kicker to Sundown ? or has this thread morrfed ? i got lost in all the long winded quotes, i say hes set in his ways and has no intrest in concidering someone else's oppinion. right or wrong in his mind hes right so i defer to my earler statment... you cant convence crazy people their wrong...
  6. Lord Baccus
    ebay box
    i would addvise aginst it as it says "Custom" but fails to mention for what sub it was designed, so custome being the oppretive word here ? id go to a local shop and get it Custom built for YOUR sub, or give us the T/S and ill plot you a cut sheet for a boxx you can build yourself. will need to know max highth wigth depth of where the box will be placed, and what kind of music you lisen to so we port it to the correct freq: also if you intend on going to competition or is this a Street beatter Hell i bet the guys in the Fi forum can tell ya what the box should be ill plott it for ya and theres nothing like smilling and telling people you built it yourself.
  7. i use the Massive P3000.1 its freeking a Huge amp. nothing small here needs Hella Battery power + Alt it is 2ohm stable mono 1ohm stable per side, as it is 2 of the P1500d's in 1 case strapped internally. with the 3ooowatt heat sinks, i have burppppppp it @ 1ohm Mono for competitions, with no problems, you deffinetlly wanna rollllllllllllllllllllllllllllll the volume to help with impedance rise ! trying to burp wide open sends it into protect... using an 8v & 6v battery seiresed to 14.97v agine with no problems... did 151.db with 2 SoundStream 15" subs
  8. Lord Baccus
    http://pierceaudioproducts.com/forum/index.php?topic=3.0 http://profile.myspace.com/index.cfm?fusea...2a-5090709f8d20 they can re-cone or custom make ya a subb if ya like
  9. Lord Baccus
    ??? Wow Bro thats outta left field !!! i dident hear that from John, someone @ a competition in Ft Worth TX was talking about Fi subs and i was just lisenning in why would you think John had anything to say about Fi ?
  10. Lord Baccus
    have read great things about them but never seen a Fi sub go Live... was told designer from RE jumped shipp and started his own Co ??? they look impressive.
  11. Lord Baccus
    I had these made for SPL... i have allways had subs with Heavy cones and Bigg Motors, so i was thinking if i got a sub built with a really Stiff cone that would take about 1000rms i can over power em by about 500rms each for burps without killing em and get a better SPL #
  12. Lord Baccus
    Wow !!! what did i miss ??? I'll tell you what my Mother taught me... You cant convence crazy people there wrong. equivalent to arguing with a brick.
  13. Lord Baccus
    the T/S i copied from their web/site this is what the regular WMDs look like: WMD15d2 Revc=4.0 ohms (both V.C.'s in series) fs=28hz qes=1.05 qms=7.34 qts=.92 vas=3.37ft^3 bl=15.25 sens=88db@2.83vrms
  14. Lord Baccus
    ill chime in for what its worth !!! i have a friend that is running the SAZ1500d @ 0.5ohm sence he got it and for months on end now he has had NOT 1 Problem... ( Nuff Said ) the only reason i got the Massive p3000.1 is i got a Hella Deal on it !
  15. Lord Baccus
    going to finals
    it was hot & Hummid --- w/ 2 dead batterys got a 148.1db all i needed was 2 points to go to finals so i am in there
  16. I like that idea gonna steal it
  17. Lord Baccus
    going to finals
    1. Move to Texas... 2. did you notice the Hottie on my right rubbing her personallity on my arm wow Frim... & all the cute 1s were inside
  18. Lord Baccus
    Gain, Hz, and Db
    sweet, so i turned my bass boost all the way down, my gain about 1/5th up and my hz on about 70 out of 200..and my amp still gets hot, so i seperated my ground wire from my power wire and hopefully that will help. A friend told me that might do it..? Id run a fan but then id feel like i cracker rig'd it sooo im not gonna do that. space amp 1/2" off floor add squirrle cage fan to keep the amp cool
  19. Lord Baccus
    my spl car
    Dammmmmmmmmmmmm thats Sweeeeeeeeeeet !!! im only 4db behiend ya
  20. what is the differance in a Double Stack or Tripple Stack sub ??? how does it affect the preformalce ?
  21. Lord Baccus
    Gain, Hz, and Db
    will my DMM do that ??? what meter is it ?
  22. Lord Baccus
    Crude box plans for a 12" SSD w/ copper
    Sweet! So honored the all-knowing ramos is helping me out. From the bcae calculator: Height? = 15 Inches Width? = 35 Inches Depth1? = 6.5 Inches Depth2? = 9.5 Inches If the above dimensions are OUTSIDE dimensions, enter the thickness of the wood below. Wood Thickness = .75 Inches Total box volume = 1.701 Ft3 And from the SSD enclosure recommendations: Ported box we recommend using 1.8-2.5 cubic feet @ 33Hz (this is optimal in our eyes and to our ears, you can tune 31-35hz fine if you so please) Looks like I'm a tad short on total volume. I could bump up the Depth1 and Depth2 numbers but would like to hear a noticeable change going from my sealed box in the pics to a ported. If I can't be louder and retain the tightness, I might stay sealed. Thanks much! aggreeded ported will give you a better bass responce from the lower freq range
  23. i personaly dont care for JL subs but that just me... overpriced paperweight...tencil leads break to easy
  24. all i saw that was close was the basket... and its sad if they went through all the trouble to copy a JL !!! i would think there are common parts from "Build Houses" unless JL has a patin on that basket ??? i saw a Funkin sub that looked just like a Soundstream from the side but the cone / spider / coil were different
  25. Lord Baccus
    SECURING YOUR SUBWOOFER
    pics please
