1,343 -
Content Type
Profiles
Forums
Gallery
Everything posted by Lord Baccus
Thank you the boxx position was not the way i normally meter / with the boxx layed down / subs up / ports back i lose 3db off the top / but it was my only option as i scouted the competition and / Stock 600-1800 was my best chance of a fare competition as the others in Mod had the addvantage !!! i did testing earller that morning and with the box in the normal position i was doing a 151.7db on the Glass & a 152.7db in the kick... without getting on it full tilt
Need Tipps on Gain Matching Amps
Lord Baccus posted a topic in Amplifiers / Head Units / Processors / Electrical
I am going to Gain match the Amps using a Dmm & an O-scope, anyone done this ? have any input on how to get the most outta the amps without Overdriving them ??? just want to do it different than Strapped any constructive suggestions or input is welcome -
im running 2x 15" PAP WMD^2 strapped SAZ 3000d's to them in a 12.75cf box, ported @ 25Hz they havent gotten warm enuff to smell the glue burn off yet !!! those are carbon/fiber cones get what ever you think youll like and can afford i just offered these as a suggestion / been lissening to them play music for 2 weeks now and they Slamm Low notes / non-fading Bass in my Spl box 7cf ported @ 54Hz they did 154.4db
Awwwwwwww Weeeeeeeeeak video !!! i wanna @ least hear the amps trying to destory some subs
i used a grinder !!! make sure you put tape over the coil-gap so as not too get stuff in there
Im going to go out on a limb and say he MIGHT have did a 169.3db with the Mic ( IN THE PORT )
My version of an SQ / music boxx
Lord Baccus replied to Lord Baccus's topic in SPL & SQ / Fabrication
i am going to have it metered and find out what it wound up being / i had planned on the ports being 27" / but with the wood i had it wound up being 24.75" so i think its tuned to about 28Hz i just wanted to try something different closer to SQ / take a walk on the SQ side of life i know its not an 8" sub but it was as close as i could get with the equipment i had on hand, thats why i contacted PAP and had them build a set of Musical subs that could take the power from Both the Sundown Audio 3000d amps i have a 12" SS SPL-X quad coil but the tollerance on the coil gap is tight like the RE MT - not ment for Music / -
I have finished the boxx for the 2x 15" WMD^2 subs w/ carbon fiber cones. wanted to have a boxx for MUSIC, not SPL the external dimentions are H- 18" W- 41.5" D- 35.5" Port was rear fireing 2x pieces 16.5" x 23.75" overall H- 16.5" W- 5" Lv- 23.75" I was shooting for 25Hz port Freq: got D@mmm Close went for a drive and it really POUNDS on the lower notes and has SMOOTH Transition between higher notes... the subs are loacted on the rear of the boxx facing Up ^^ neer the back window port fires to the rear door seperating the subs and BRACING the boxx Pics / a lil late but better than never Strapped @ 1ohm / 0.5ohm per amp DAILY
Charging up the 8V batterys
getting ready for Sicnick/Usaci in south LA !!! going to go F-with there heads planning on 3sets of 2x seires / then parallel to get close ASP to 18v any tips or CONSTRUCTIVE input is welcome -
And what do lyrics have to do with subwoofers ? Subs are not ment to play Voices,,, if you can hear someone singing through the subs you have the crossover set Wayyyyyyyyyyyyyyyyyyyy too High and will sound like
4/0 power Wire - flexible
Lord Baccus replied to Andrew2944r's topic in Amplifiers / Head Units / Processors / Electrical
welding supply -
the Range of Freq: a given type of Box can reproduce / sealed boxs do well from 45Hz up^^^ help the sub take a lil more power using the back pressure in the boxx / Ported boxxs let you get more range & tune to the Freq: you desire has a Wide roll off on both ends of the Center Freq: / BanPass Boxxs use a Sealed smaller chamber & a Larger Ported chamber to get the most outta the sub but has a limited Freq: range - one song will Slammmm and the next you wouldent know you had a sub installed because the notes are out of the Range that the box can reproduce... I hope i got this correct...
SADD but True it was a 4th order banpass that i tried winnging off the top of my head and it flopped Baddddddddddddddd -
pics : http://pierceaudioproducts.com/forum/index...opic,162.0.html This is designed to take both of my SAZ 3000d amps DAILY / Street Beat
Videos: 2 Custom Nightshade 18"s on 2 saz-3000Ds
Lord Baccus replied to spl_explorer's topic in Sundown Audio
Ummmmmmmm ??? Sub Porn Please !!! I like seeing the subs -
Ups showed up and the Box was Crushed !!! looked like they had run into it with a forklift a few times Basket was Shattered / UPS driver would not let me take pics of it so i REFUSED it / the next one will have to have a Frame/crate built inside the cardboard box, it was completlly distroyed ( the box i mean ) thats why i insisted on openning it to see if the sub had survived / it had not The box was obliterated and looked as though it had been dropped from the 2nd floor of some building... UPS has Crushed my Soul !!! I was going to build the X1 enclosure and Dominate the Sicknic/Usaci here in South LA oh well on too Plan B i'll use the Bigg Boxx too do Street Beat Class / and then on the 2nd day ill pull out the Beast and SPL em too death
the gule was from previous attempt to build a box i saw in a supermodd van / i had did a ruff estimate and cut the dimentions in half thinking it would slamm @ss in the SUV and it did above 90Hz, but not below 80Hz this was the boxx that Floopped so i took it appart and rebuilt it into the Bigg 25Hz Beast -
Impressive
and YOU KNOW THIS !!!!!!!!!!!!!!!!!!!!!!!!!! > -
I am going too build A T-line or a Folded Horn for the 12" but as of this comming Monday i have a Custom built 18" Beast arriving UPS going to build an X1 enclosure see>>> http://www.speakerplans.com/index.php?id=x1 -
Thank you i did round off the port corners & got the boxx finnished / carpetted etc etc etc Looks Freeking Sweeeeeeeet will post pics later -
i tuned it too the Fs of the cone i gotta say it is nice being able to hear the notes that fade out on a box tunned higher / this thing has the Flattest responce iv seen on a plot/cruve. it does play clean and clear @ lower freq, i had ordered those sub built to take the power i was going to use and had 2 spiders & additional pole venting too keep the coils cooler i have been pounding them in an 11cf enclosure for 2 weeks now and i havent smelled the Glue burn off yet they havent gotten warm enuff with 2x 3000d amps STRAPPED playing in a box ported @ 25Hz !!!!!!!!!!!!!!!! AMAZING i know its not the tipical SQ box, and thank you for the kind input... do you think i should round off the corners on the Port openning ? @ lower volumes i can hear faint port turbulance... -
Lets see the pics of what cha beat him with
ditto x2 /// BAD IDEA...
Get in touch with Doug B from TBP he is a Master @ re-conning subs
