Accuwave
'06 Euro-Civic(FK2) Simple SQ Build
Hello world.
Well, here's my Civic build. It's a simple SQ setup.
Front stage: 2way DLS UR6i
Sub: mac Audio Aliante 10" Black LTD
Front amp: Helix H400 Esprit
Sub amp: Steg QM 220.2
Stock HU as signal source and re-used Pioneer P88RS as signal processor. (HU>LOC>P88 aux in)
It's an unusual configuration, works for now, but I'm really thinking about an Audison Bit Ten.
Doors were deadened with SilentCoat, but I still have some work to do on them.
Cables are AWG4, and hand"crafed" RCAs.
Here's the car - or egg-shaped rocket ship, as some may call it:
post-18968-0-35600900-1367754674_thumb.j
post-18968-0-90431700-1367754607_thumb.j
Old picture of the dash, pre-install (the same, but OEM tweeters):
post-18968-0-77622600-1367754770_thumb.j
Overall requirements of the install were:
1. Keep everything fully functional, including AC/Radio Display and steering wheel controls.
2. Do not waste space and do not remove spare wheel (we've got potholes in the land of Dracula)
3. "Removability" - I don't want to sell everything when I sell the car, nor I want to buy un-modified interior parts to make it stock-looking.
4. Good SQ, I'm not at all after bigbase or anything SPL-related. As fun as it may be, it's not for me.
So...
First, I made an amp rack.
Simple particle board. It just fits 2 amps, distro blocks and a small relay board.
post-18968-0-44266000-1367755330_thumb.j
Techflex on most of the cables. And MOLEX connectors for the speakers(1 for midbass, 1 for tweeters). After connecting everything I thought it would have been better to use the connectors for left/right pairs. On my to-do list.
I passed the speaker cables through copper tubes, just for the fun of it...
post-18968-0-54851900-1367755435_thumb.j
Mounted on the left side of the trunk (and yeah, I know the Steg is sticking out):
post-18968-0-59933000-1367755639_thumb.j
And now, the big mid-bass that goes in the trunk:
post-18968-0-61980600-1367755825_thumb.j
post-18968-0-20101100-1367755859_thumb.j
Now, the fiberglass subwoofer enclosure.
This was my first attempt at building one, so I messed up a few times, but quite satisfied of the final result.
post-18968-0-50640600-1367756018_thumb.jpost-18968-0-52984000-1367756023_thumb.jpost-18968-0-16997500-1367756026_thumb.jpost-18968-0-88198900-1367756028_thumb.j
post-18968-0-66478500-1367756033_thumb.j
Enclosure is sealed, but I made it easily vent-able... The round thingey is actually a plug for the port hole. Just need to make another round thingey with a port.
Finally:
A crappy picture.
post-18968-0-69866200-1367756209_thumb.j
Well, that's most of it. Still have to work on the doors and some prettyfication.
And better photos.
Edited by groowe
very well done, i like how neat everything is. Though i will ask about your box. If its sealed typically you need 1cu ft of air space behind the subwoofer, but if its ported you usually need a minimum of 1.5 for it to sound good. How are you adjusting for that?
Well, I've made some bassbox stimulations and with the volume I have there are some possibilities... with a ridiculously long port. Still haven't tried yet.I'm satisfied for the moment. I'll cross that bridge when I get there...
nice work. how did u get the civic letters behind the carpet? did u just take the label and carpet over?
I had the logo cut out of ABS plastic on a CNC and just carpeted over it....
You know...the box sucks, bad. You know why? :P
Shouldn't have an aliante in it? :))
1. You got it right on the first go
The OP has had some really cool installs, it's nice to see someone local on the board smile.png
1. But I might have gotten something wrong... If not for 2.
Cool installs is an overstatement. I did what could be done.
More pics:
The tweeters fit perfectly in the stock locations:
post-18968-0-88994900-1367845388_thumb.j
post-18968-0-75189400-1367845387_thumb.j
And the pretty guy just sits there, and does his job:
post-18968-0-85444700-1367845386_thumb.j
And a better view of everything in the trunk(still not perfect):
post-18968-0-00830300-1367845386_thumb.j
post-18968-0-06091300-1367845385_thumb.j
How do you like the final results : sound, look ?
Nice equipments, but I don't know this sub.
I like the fact that you have room left in the trunk ;) Well played !
I like the fact that you have room left in the trunk wink.png Well played !
Final results... Sound is good enough... but could be lots better with just the equipment I have. Still have to bring the midbass drivers out(the stock locations are far behind the door panel). And the tweeters placement is quite awkward, one is on-axis and one is off-axis, so I have to figure that out too...
Looks are decent, a bit annoyed with the mis-matched amps, but I can live with that.
The sub is actually a Phase Linear Aliante(build under license by mac). Pure SQ sub. Doesn't really move that much air(but it eats up 400W like they're nothing), it's mainly a 10" midbass driver. But it's really smooth, fast and it blends in perfectly with the front stage.
Well, this is awkward. Updates with upgrades.
Traded in my P88 and 150$ for:
The guy who sold it to me said it had noise issues, I've tested it on a lab power supply, updated the firmware and ... there's no unwanted noise whatsoever. Still, fingers crossed for when I install it.
Edited by groowe
Well, it's all installed, using the high level inputs there is no noise, the only thing I've noticed is a digital beeping noise caused by the DRC(as I've read) - when using AUX inputs AND the source(phone) is connected to the charger... so it's probably a ground loop somewhere. Probably easily fixable.
Sound wise it's not an improvement. That would be an understatement. I've rediscovered my speakers and amps. Still have to tune a bit, but everything is already so much better.
Well, late night install time. Just managed to fit the remote, looks decent biggrin.png
Soon I'll relocate the audison in the trunk and there's some fabrication required...
post-18968-0-86425700-1368570120_thumb.j
Edited by groowe
Prototyping time:
Operation port.
post-18968-0-56166200-1372798393_thumb.j
The Aliante is disturbingly weak in a sealed enclosure, so I had to port it. Big difference, tuned to around 40hz right now, still want to go lower. I just need a lot of plastic tube :| And somehow integrate everything so it doesn't look awkward.
New "head unit".
Also, Faital 3FE20 fullrange drivers.
Still more to come: digital output from tablet(HDMI port), steering wheel remote on tablet(bluetooth), new sub(JL W6/W7).
But for now:
Looks real good, I been wanting to try out those Faitals and for the price they arent bad. How do you like them so far?
The faitals are interesting, crisp top end, but somehow dry in the midrange. They're not bad in any way though.
Thats good to know, are you using them with a tweeter?
No, high passed at about 150-175hz, and that's it. Don't really need a tweeter. I have the stock ones mounted just for design purposes.
    1. Recent Topics
        • 1 comment
        • 46 views
        • 1 comment
        • 36 views
        • 1 comment
        • 42 views
      1. Box for 1 15" SSA ICON
        • 3 comments
        • 892 views
        • 8 comments
        • 1,815 views
        • 1 comment
        • 79 views
  • Similar Content
    • By Shogen
      Parting with my beloved 80PRS .... Don't really want to see her go but I'm not one to waste amazing hardware
      SOLD
       PayPal verified only ...
      Unit is in great condition. Comes with bluetooth mic and TA mic. Also has wiring harness and remote plus faceplate case
      Photos below (sorry if not great but taken with iphone 7 plus aka my next listing)
    • By Shogen
      Like the title says.... Getting rid of this bad boy, has all accessories (even the GPS antenna) except USB wire which you can pick up any where (USB extension cable).... I will let this go for $675 shipped....
      Price:  $675
      PAYPAL ONLY
      Shipping within continental US only
      ***MODs I took photo last night but had issues getting onto the PC hope yesterday date ok***
      Buy with confidence, long time member of the community...
    • By Thomas Iturraran
      Vehicle : 1973 VW Beetle
      Location in the vehicle: Rear cargo area; sub pointed up
      Space available (Length x Width x Height): 35" length x 12" depth x 12-15" height
      Subwoofer make and model: Fi SSD
      Subwoofer Size: 10
      Number of Subwoofers: 1
      Type of Port (Kerfed, Slot, Aero, etc.): Rectangle w/ 45's
      What type of music do you like?: EDM, RAP, Rock,
      Is your goal SPL or Everyday Music?: Everyday high sq
      Tuning Freq (Hz): 35 - 38hz?
      Volume : 1 - 1.5?
      Questions:
      So I have modeled up a few different enclosure in win isd but I just want some confirmation as to what you guys think will work best for my listening needs. From what I have read on this forum that I believe Fi recommends a tuning between 31-35hz and 1.5 cu ft. Modeled the box up they suggest and some of the numbers in win isd don't seem to comply with recommendations I find online, for ex. port velocity seems way too high ~ 130ft/s and output seems to lack around the 40-50hz region. From what I understand it seems as though when designing a box in a small vehicle such as my VW you can go a little bit higher due to cabin gain if I understand correctly. After modeling it seems as though 1-1.25 cu ft and a tuning of 38hz seems to produce a nice curve that also had minimal group delay and won't produce a ridiculous peak in output. My question is are there any other suggestion as to maybe more box volume or less and will there be any unforeseen issues with tuning to 38hz instead of 35? Also can someone give me any insight on how tuning affects subs ability to play in the 60-100 hz region? If I understand correctly tuning lower limits the sub woofers ability to play the higher notes?
    • By boxbuildshoutout
      Hello everyone I would like to start by saying I have no intention of breaking or bending any site or community rules here so pls forgive me if I do that is not my intention.
      I am here to share my personal experience with cherrymancustoms who has built me an extremely personalized and truly custom enclosure to meet the needs of my particular listening goals.
      This man has spent literally countless hours over-the-phone speaking with me one on one in an attempt to maximize my enclosure design and has built what I consider to be a very good quality box. I have attached images for your own viewing and judgement below.
      His website is www.cherrymancustoms.com/ where he has a phone number listed for you to contact him if you so choose to do. He also has a YouTube account and forum thread over at caraudio.com
      I plan on again encouraging him to create an account here so he can communicate with you guys easily and share all of his work here locally with the community.
      FYI this box was built with an adjustable internal volume and adjustable tuning plus it is "double walled" everywhere from top to bottom and side to side. It features some serious bracing too.
      For any of you looking for someone to build and create exactly what you have in mind or rather those of you who need somebody to help you determine what would be best for your needs I strongly encourage you to give this man a chance he is super friendly, knowledgeable and hard-working as you can see.
      Best of wishes to everyone here hope some of you may find this information to be of good use.
  • Recent YouTube Posts
