tweak_09
Members-
44 -
Content Type
Profiles
Forums
Gallery
Everything posted by tweak_09
2 15 FI Bls fully loaded, spl in cab of avalanche...
tweak_09 replied to tweak_09's topic in Subwoofers / Speakers
naaa...not bad at all i was kind of suprised. -
sounds great....... -
yea...i was waiting to see if anybody else had any say on this...but i dont think it would even rattle as bad as a trunk would cause it locks in pretty tight and is cushioned by foam. -
will do -
yup...i guess i will find out tommorrow when i try it out.. -
gah...i know, ive been there. way over my price range haha. im just talkin about puttin a box i built for my bls in the bed of my truck with the midgate up and everything, and it still sounding good...wouldnt it be like subs in a trunk? -
any body have any more in-depth info on this??? have you heard somthing like this before? -
haha...na i dont mind that. but do you know what an avalanche looks like?...you can seal the cab off from the bed of the truck but the midgate folds down and there are 3 bed cover that clip on. i just wanted to make sure that it would still sound alright if i put my box into the bed of the truck and keep the tops on the bed of the truck. -
id like to know why my 4000 watt amp wont push 1 15 Bl fully loaded without blowing both my 40 amp fuses in it.
sub blowing my 4000 watt amp with two 40 amp fuses.
tweak_09 replied to tweak_09's topic in Fi Technical
i also had one more question....do you think if i made a box that is ryhno lined for my bl and put it inthe bed of my avalanche, would it still sound somewhat good??? -
alright lol...sounds good. -
that amp hooked up to just one bl should be fine...power wasnt a problem it was my dumb ass that wired the sub to a 1 ohm impedence, and didnt realize it. im plannin on selling this bl and buying a 15 btl hooked up to a US amps xt4000d, sound good? -
damn...thanks man. i was worried i was completly fudgeed and had to buy a whole new amp and chit. but it works, thanks. -
alright...iill try it out. thanks alot. -
oh and each diamond is dual 2 ohm i have the Bl fully loaded dual 2 ohm with spl. -
MXA282-4000 Watt 2 Channel High Power MOSFET Amplifier SPECS 2 x 1000 Watts RMS at 4 Ohms 2 x 2000 Watts Max at 4 Ohms 1 x 4000 Watts Max at 4 Ohms Bridged 2 x 1650 Watts at 2 Ohms RMS Electronic Crossover Network Bass Boost Circuit Variable Phase Shift Control 2 Ohms Stereo Stable Anti-Thump Turn-On Soft Turn On/Off High & Low Level Inputs Blue Light Illuminated Crossover Control Power & Protection LED Indicators Advanced Protection Circuitry Bass Boost Remote Control T.H.D: 0.04% S/N Ratio: 90dB Channel Separation: 65dB Frequency Response: 15Hz- 35kHz Dimensions: 10.47''W x 2.46''H x 21''L I have the sub wired like this....i have a negative to negative on the sub, then positive to positive, then a negative and a postive to the amp at 4 OHMs -
i havent put the sub in a box yet...i was free airing it, but still, i shouldnt be blowing 40 amp fuses one after another. -
i have a 4000 watt 2 channell lanzar amp...not the best brand. But my friend has the same amp and he is running 2 Diamond audio D9's off of it and they do just fine...Then when i tried plugging my Bl into His amp i blew his fuses too...my ground is fine.
